Forum / Workstations
How do I check my mini PC's temperature
SamTinkers OP
My mini PC is going to live on the one shelf in our apartment, tucked next to the router, and it'll be on all day. It's pretty small and the vents are tiny, so I keep worrying it'll cook itself without me knowing. The fan runs and the case feels warm to the touch, but I don't know if warm is normal or a problem.
I've seen people mention checking temps with a program but I don't know which one, or what number is too hot. i'm still working out Linux, so I'd rather not do anything fancy. Is there a simple tool that shows the temperature, and what range should I treat as fine? Also, is leaving a bit of space around it enough, or do I need a small fan?
