The question: for a small office, do you run WPA3-Personal, WPA2/WPA3 transition mode, or WPA2-Enterprise with RADIUS, and what actually broke when you changed it? I have a lean, but I'd like to compare it with yours.
I do this for a few nonprofits, and the pattern is always the same. The security setting is the easy part. The old gear is the hard part. A ten-year-old laptop with a Wi-Fi card that predates WPA3 will not see a WPA3-only network as joinable. Sometimes it doesn't see it at all. Printers are worse, because they often have the oldest radio in the building and no way to update it. Think of changing the lock on the front door and finding out the cleaner has the only key to the old one.
My lean:
- Transition mode is a bridge, not a destination. It lets WPA2 clients keep working while newer ones use WPA3. But the AP is still accepting WPA2, so you've gained less than the label suggests. Some older clients also get confused by it. I've seen that, but I can't say how widespread it is.
- WPA3-only is fine when you can list every device and know each one supports it. Few offices can.
- WPA2-Enterprise is the real improvement, because each person gets their own credentials and you can revoke one without touching the others. The cost is a RADIUS server, certificates, and someone who will keep them current. For six desktops and a printer, I think that's usually too much to carry.
- The printer fix I like best is to move it to its own SSID or wired connection, and keep the main network stricter.
I haven't tested every printer brand, so I won't claim to know which ones choke on what.
What did you pick for a small office, and what was the first device that stopped connecting? Did you end up with a separate network for the stragglers?
