Forum / General / Community Projects
Sizing UPS runtime for a fanless firewall and two managed switches
RackGhostDwayne OP
The question: has anyone put a small battery backup, or a small solar setup, behind a rack of network gear, and how do you size the runtime for a fanless router plus two managed switches? I have a method, but I would like to compare it with yours.
The network gear is the easy load. It draws little and it draws steadily. My lean is to measure first and calculate second. Put a plug-in watt meter on the strip for a day and write down the highest reading, not the average. Switches with PoE devices behind them will surprise you.
Then the arithmetic is short:
runtime (hours) = battery Wh x usable fraction x inverter efficiency / load W
Example with made-up round numbers: a 12 V, 7 Ah battery is about 84 Wh on the label. Assume half is usable and the inverter is 80 percent efficient. That is about 34 Wh. At a 40 W load, you get roughly 50 minutes. I would treat that as the optimistic end. Old batteries give less, and the UPS itself draws power just sitting there.
So what do I want from the runtime? Not hours. I want enough time to ride through a short outage and to shut things down cleanly if it drags on. That is a very different size than "keep the internet up all night."
Solar is outside my experience. My worry is the extra conversion steps and one more thing to maintain in the basement, and I like setups that need no attention. If I tried it, I would start with the battery side and add the panel later.
  1. What load did you actually measure, and how far off was your guess?
  2. If you went past a plain UPS, was the added complexity worth it after a year?
Dwayne
