I'm close to getting a used mini PC and I'd like to practice Linux on it before I run anything the household depends on. My partner works from home and has video calls most days, so I really don't want to be the reason the Wi-Fi drops.
If I plug the mini PC into the same router as everything else, can a mistake on it take down the network? I think the risky part is anything that changes network settings, like a static IP or something that hands out addresses, but I'm not sure. Is it safe to just install Linux and mess around, as long as I don't touch the router? And is there a simple way to keep it separate until I know what I'm doing, without buying a managed switch?
