Successful exploitation of this vulnerability could result in information disclosure, including capture of camera account credentials.
The following versions of ZKTeco CCTV Cameras are affected:
  • SSC335-GC2063-Face-0b77 Solution
v3 9.1 ZKTeco ZKTeco CCTV Cameras Authentication Bypass Using an Alternate Path or Channel
  • Critical Infrastructure Sectors: Commercial Facilities
  • Company Headquarters Location: China
CVE-2026-8598
An undocumented configuration export port is accessible on some models of ZKTeco CCTV cameras. This port does not require authentication and exposes critical information about the camera such as open services and camera account credentials.
ZKTeco CCTV Cameras
ZKTeco
ZKTeco SSC335-GC2063-Face-0b77 Solution:
ZKTeco has patched this vulnerability in firmware version V5.0.1.2.20260421. ZKTeco recommends that users upgrade to firmware version V5.0.1.2.20260421 or later at their earliest opportunity.
Please see the security advisory from ZKTeco here: https://www.zkteco.com/en/announcement/23 for further information.
Relevant CWE: CWE-288 Authentication Bypass Using an Alternate Path or Channel
3.1 9.1 CRITICAL CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:N
  • Souvik Kandar reported this vulnerability to CISA
  • Initial Release Date: 2026-05-19
2026-05-19 1 Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-139-04
