Saltar al contenido principal
IT BIBLEIniciar sesión
Kieback & Peter DDC Building Controllers
Successful exploitation of this vulnerability could allow an attacker to take control of the victim's browser.
The following versions of Kieback & Peter DDC Building Controllers are affected:
  • DDC4002 <=1.12.14 (CVE-2026-4293)
  • DDC4100 <=1.12.14 (CVE-2026-4293)
  • DDC4200 <=1.12.14 (CVE-2026-4293)
  • DDC4200-L <=1.12.14 (CVE-2026-4293)
  • DDC4400 <=1.12.14 (CVE-2026-4293)
  • DDC4002e <=1.23.4 (CVE-2026-4293)
  • DDC4200e <=1.23.4 (CVE-2026-4293)
  • DDC4400e <=1.23.4 (CVE-2026-4293)
  • DDC4020e <=1.23.4 (CVE-2026-4293)
  • DDC4040e <=1.23.4 (CVE-2026-4293)
  • DDC520 <=1.24.1 (CVE-2026-4293)
v3 5.3 Kieback & Peter Kieback & Peter DDC Building Controllers Improper Neutralization of Input During Web Page Generation ('Cross-site Scripting')
  • Critical Infrastructure Sectors: Commercial Facilities, Communications, Financial Services, Food and Agriculture, Government Services and Facilities, Healthcare and Public Health, Information Technology
  • Countries/Areas Deployed: Austria, China, France, Germany, United Arab Emirates
CVE-2026-4293
The affected products are vulnerable to cross-site scripting (XSS), enabling JavaScript to be executed by the victim's browser, which allows the attacker to control the browser.
Kieback & Peter
Kieback & Peter DDC4002: <=1.12.14, Kieback & Peter DDC4100: <=1.12.14, Kieback & Peter DDC4200: <=1.12.14, Kieback & Peter DDC4200-L: <=1.12.14, Kieback & Peter DDC4400: <=1.12.14, Kieback & Peter DDC4002e: <=1.23.4, Kieback & Peter DDC4200e: <=1.23.4, Kieback & Peter DDC4400e: <=1.23.4, Kieback & Peter DDC4020e: <=1.23.4, Kieback & Peter DDC4040e: <=1.23.4, Kieback & Peter DDC520: <=1.24.1
Kieback & Peter DDC Building Controllers are developed and designed for use in closed building automation networks. The system is protected by a multi-level perimeter against attacks, especially from outside, by dividing it into operational technology (OT) zones with firewalls. Building automation systems (BA systems) in general should not be directly accessible from untrusted networks, especially from the Internet, but should be protected by consistently applying the defense-in-depth strategy. This concept is supported by organizational measures in the building as part of a safety management system. In order to achieve safety, measures are required at all levels.
The DDC4002, DDC4100, DDC4200, DDC4200-L and DDC4400 controllers are end-of-maintenance, therefore the recommendations for these devices are as follows: These devices must be operated in a strictly separate OT environment.
The DDC4002, DDC4100, DDC4200, DDC4200-L and DDC4400 controllers are end-of-maintenance, therefore the recommendations for these devices are as follows: Only trusted individuals should be granted network access to the DDC web portal.
The DDC4002, DDC4100, DDC4200, DDC4200-L and DDC4400 controllers are end-of-maintenance, therefore the recommendations for these devices are as follows: Access to the web portal should be disabled in the device configuration if not required.
The DDC4002, DDC4100, DDC4200, DDC4200-L and DDC4400 controllers are end-of-maintenance, therefore the recommendations for these devices are as follows: Users should be informed that only links from trusted sources should be used to access the web service.
For the DDC520, DDC4002e, DDC4200e, DDC4400e, DDC4020e, and DDC4040e controllers, Kieback & Peter recommends the following safety measure: Restrict network access to the device
For the DDC520, DDC4002e, DDC4200e, DDC4400e, DDC4020e, and DDC4040e controllers, Kieback & Peter recommends the following safety measure: Do not directly connect the device to the Internet
Update the firmware to the latest available version: DDC4002e -> Update to version 1.23.5 or newer
Update the firmware to the latest available version: DDC4200e -> Update to version 1.23.5 or newer
Update the firmware to the latest available version: DDC4400e -> Update to version 1.23.5 or newer
Update the firmware to the latest available version: DDC4020e -> Update to version 1.23.5 or newer
Update the firmware to the latest available version: DDC4040e -> Update to version 1.23.5 or newer
Update the firmware to the latest available version: DDC520 -> Update to version 1.24.2 or newer
3.1 5.3 MEDIUM CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:L/A:N
  • Maximilian Hildebrand of G DATA Advanced Analytics reported this vulnerability to CISA
  • Initial Release Date: 2026-05-19
2026-05-19 1 Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-139-05
