ABB B&R Automation Studio
ABB became aware of vulnerability in the product versions listed as affected in the advisory. An update is available that resolves a vulnerability. Successful exploitation of this vulnerability may enable an attacker to masquerade as a trusted party when B&R Automation Studio establishes a connection with a server via the ANSL over TLS or OPC-UA protocol.
The following versions of ABB B&R Automation Studio are affected:
  • Automation Studio <6.5, 6.5 (CVE-2025-11043)
v3 7.4 ABB ABB B&R Automation Studio Improper Certificate Validation
CVE-2025-11043
An Improper Certificate Validation vulnerability in the OPC-UA client and ANSL over TLS client used in Automation Studio versions before 6.5 could allow an unauthenticated attacker on the network to position themselves to intercept and interfere with data exchanges.
ABB
ABB Automation Studio <6.5
fixed, known_affected
The problem is corrected in the following product versions: B&R Automation Studio version 6.5 B&R recommends that customers apply the update at earliest convenience. The process to install updates is described in the user manual. The step to identify the installed product version is de-scribed in the user manual.
To exploit this vulnerability, an attacker would need to intercept and redirect the communication between B&R Automation Studio and the target server, as well as present manipulated certificates that pass validation checks. B&R recommends operating B&R Automation Studio within Level 2 of the ABB ICS Cyber Security Reference Architecture when connecting to Level 1 devices via ANSL over TLS or OPC-UA. Operating in this trusted environment reduces the risk of successful exploitation drastically. Refer to section “General security recommendations” for further advise on how to keep your system secure.
Relevant CWE: CWE-295 Improper Certificate Validation
3.1 7.4 HIGH CVSS:3.1/AV:N/AC:H/PR:N/UI:N/S:U/C:H/I:H/A:N/RL:O/RC:C
  • ABB PSIRT reported this vulnerability to CISA.
Notice
The information in this document is subject to change without notice, and should not be construed as a commitment by B&R. B&R provides no warranty, express or implied, including warranties of merchantability and fitness for a particular purpose, for the information contained in this document, and assumes no responsibility for any errors that may appear in this document. In no event shall B&R or any of its suppliers be liable for direct, indirect, special, incidental or conse-quential damages of any nature or kind arising from the use of this document, or from the use of any hardware or software described in this document, even if B&R or its suppliers have been advised of the possibility of such damages. This document and parts hereof must not be reproduced or copied without written permission from B&R, and the contents hereof must not be imparted to a third party nor used for any unauthorized purpose. All rights to registrations and trademarks reside with their respective owners.
Frequently Asked Questions
What causes the vulnerability? - The vulnerability is caused by insufficient validation mechanisms for server certificates in the ANSL over TLS and OPC-UA client implementations. What is B&R Automation Studio? - B&R Automation Studio is an environment for developing and executing automation solutions, ranging from control and motion technology to HMI, operation, and integrated safety technology. What might an attacker use the vulnerability to do? - An attacker who successfully exploited this vulnerability could spoof a trusted server, potentially leading to the disclosure of confidential information or the alteration of data during transit. How could an attacker exploit the vulnerability? - An attacker could attempt to exploit this vulnerability by generating a maliciously crafted server certificate and manipulating network routing or name resolution to redirect traffic through a compromised node under their control. This would require that the attacker has access to the system network, by connecting to the network either directly or through a wrongly configured or penetrated firewall, or that he installs malicious software on a system node or other-wise infects the network with malicious software. Recommended practices help mitigate such attacks, see section Miti-gating Factors above. Could the vulnerability be exploited remotely? - Yes, an attacker who has network access to an affected system node could exploit this vulnerability. Recommended practices include that process control systems are physically protected, have no direct connections to the Internet, and are separated from other networks by means of a firewall system that has a minimal number of ports exposed. What does the update do? - The update removes the vulnerability by modifying the way that the ANSL and OPC-UA clients are validating server certificates. When this security advisory was issued, had this vulnerability been publicly disclosed? - No, B&R discovered this vulnerability as a part of its own security analysis. When this security advisory was issued, had B&R received any reports that this vulnerability was being exploited? - No, B&R had not received any information indicating that this vulnerability had been exploited when this security advisory was originally issued
This ICSA is a verbatim republication of ABB PSIRT SA25P004 from a direct conversion of the vendor's Common Security Advisory Framework (CSAF) advisory. This is republished to CISA's website as a means of increasing visibility and is provided "as-is" for informational purposes only. CISA is not responsible for the editorial or technical accuracy of republished advisories and provides no warranties of any kind regarding any information contained within this advisory. Further, CISA does not endorse any commercial product or service. Please contact ABB PSIRT directly for any questions regarding this advisory.
  • Initial Release Date: 2026-01-19
2026-01-19 1 Initial Version
2026-05-05 2 Initial CISA Republication of ABB PSIRT SA25P004 advisory
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-125-04
