Saltar al contenido principal
IT BIBLEIniciar sesión
Siemens SINEC NMS when used with User Management Component (UMC) contains an authentication bypass vulnerability due to insufficient validation of user identity. This could allow an unauthenticated remote attacker to bypass authentication and gain unauthorized access to the application. Siemens has released a new version for SINEC NMS and recommends to update to the latest version.
The following versions of Siemens SINEC NMS are affected:
  • SINEC NMS
v3 7.3 Siemens Siemens SINEC NMS Improper Verification of Cryptographic Signature
CVE-2026-24032
The affected application contains an authentication weakness due to insufficient validation of user identity in the UMC component. This could allow an unauthenticated remote attacker to bypass authentication and gain unauthorized access to the application. (ZDI-CAN-27564)
Siemens SINEC NMS
SINEC NMS
Update to V4.0 SP3 or later version
https://support.industry.siemens.com/cs/ww/en/view/110000760/
Relevant CWE: CWE-347 Improper Verification of Cryptographic Signature
This ICSA is a verbatim republication of Siemens ProductCERT SSA-801704 from a direct conversion of the vendor's Common Security Advisory Framework (CSAF) advisory. This is republished to CISA's website as a means of increasing visibility and is provided "as-is" for informational purposes only. CISA is not responsible for the editorial or technical accuracy of republished advisories and provides no warranties of any kind regarding any information contained within this advisory. Further, CISA does not endorse any commercial product or service. Please contact Siemens ProductCERT directly for any questions regarding this advisory.
  • Initial Release Date: 2026-04-14
2026-04-14 1 Publication Date
2026-04-21 2 Initial CISA Republication of Siemens ProductCERT SSA-801704 advisory
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-111-03
