Hardy Barth Salia EV Charge Controller
Successful exploitation of these vulnerabilities could crash the device being accessed; a buffer overflow condition may allow remote code execution.
The following versions of Hardy Barth Salia EV Charge Controller are affected:
  • Salia Board Firmware <=2.3.81 (CVE-2025-5873, CVE-2025-10371)
v3 7.3 Hardy Barth Hardy Barth Salia EV Charge Controller Unrestricted Upload of File with Dangerous Type
  • Critical Infrastructure Sectors: Energy, Transportation Systems
CVE-2025-5873
A vulnerability was found in eCharge Hardy Barth Salia PLCC 2.3.81. It has been declared as critical. This vulnerability affects unknown code of the file /firmware.php of the component Web UI. The manipulation of the argument media leads to unrestricted upload. The attack can be initiated remotely. The exploit has been disclosed to the public and may be used. The vendor was contacted early about this disclosure but did not respond in any way.
Hardy Barth
Hardy Barth Salia Board Firmware: <=2.3.81
Hardy Barth did not respond to CISA's request for coordination.
Contact Hardy Barth using their contact page here: https://www.hardy-barth.de/de/kontakt for more information.
Alternatively, Hardy Barth can also be contacted through their eCharge brand here: https://www.echarge.de/en/contact_company
Relevant CWE: CWE-434 Unrestricted Upload of File with Dangerous Type
3.1 6.3 MEDIUM CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:L/I:L/A:L
CVE-2025-10371
A security flaw has been discovered in eCharge Hardy Barth Salia PLCC 2.3.81. This issue affects some unknown processing of the file /api.php. The manipulation of the argument setrfidlist results in unrestricted upload. The attack may be performed from remote. The exploit has been released to the public and may be exploited. The vendor was contacted early about this disclosure but did not respond in any way.
Hardy Barth
  • CISA discovered a public Proof of Concept (PoC) as authored by YZS17 and reported it to Hardy Barth
  • Initial Release Date: 2026-04-21
2026-04-21 1 Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-111-05
