Schneider Electric EcoStruxure Automation Expert
Schneider Electric is aware of a vulnerability in its EcoStruxure™ Automation Expert product. The EcoStruxure™ Automation Expert product is plant automation software designed for digital control systems in discrete, hybrid and continuous industrial processes. A totally integrated automation solution designed to enhance your flexibility, efficiency and scalability. Failure to apply the remediation provided below may risk execution of arbitrary commands on the engineering workstation, which could result in a potential compromise of full system.
The following versions of Schneider Electric EcoStruxure Automation Expert are affected:
  • EcoStruxure™ Automation Expert vers:intdot/<25.0.1, 25.0.1
v3 8.2 Schneider Electric Schneider Electric EcoStruxure Automation Expert Improper Control of Generation of Code ('Code Injection')
  • Critical Infrastructure Sectors: Commercial Facilities, Critical Manufacturing, Energy
CVE-2026-2273
CWE-94: Improper Control of Generation of Code ('Code Injection') vulnerability exist that could cause execution of untrusted commands on the engineering workstation which could result in a limited compromise of the workstation and a potential loss of Confidentiality, Integrity and Availability of the subsequent system when an authenticated user opens a malicious project file.
Schneider Electric
EcoStruxure™ Automation Expert Versions prior to v25.0.1
fixed, known_affected
Version v25.0.1 of EcoStruxure™ Automation Expert includes a fix for this vulnerability and is available for download here: https://www.se.com/ww/en/product-range/23643079-ecostruxure-automation-expert/
If customers choose not to apply the remediation provided above, they should immediately apply the following mitigations to reduce the risk of exploit: Solution and archive files must be stored within the user’s home directory or in any location protected by appropriate Windows file‑system access controls to prevent unauthorized access in multi‑user environments. Users who choose to store files outside their home directory are responsible for applying restrictive Windows permissions to secure those locations. Before opening any solution or archive file, users are required to verify its authenticity and ensure that it has not been modified by unauthorized users. For detailed mitigation steps, refer to the User Manual - https://product-help.se.com/EcoStruxure%20Automation%20Expert/25.0/Offer%20Guides/en-US/EAE_UM?t=EAE_UM%2FSolutionIntegrity-FE037ED3.html%3Frhhlterm%3Dundefined%253Frhsearch%253Dundefined&theme=Help
3.1 8.2 HIGH CVSS:3.1/AV:L/AC:L/PR:L/UI:R/S:C/C:H/I:H/A:H
  • Schneider Electric CPCERT reported this vulnerability to CISA.
  • Raffaele Bova of Nozomi Networks reported this vulnerability to Schneider Electric.
We strongly recommend the following industry cybersecurity best practices. * Locate control and safety system networks and remote devices behind firewalls and isolate them from the business network. * Install physical controls so no unauthorized personnel can access your industrial control and safety systems, components, peripheral equipment, and networks. * Place all controllers in locked cabinets and never leave them in the “Program” mode. * Never connect programming software to any network other than the network intended for that device. * Scan all methods of mobile data exchange with the isolated network such as CDs, USB drives, etc. before use in the terminals or any node connected to these networks. * Never allow mobile devices that have connected to any other network besides the intended network to connect to the safety or control networks without proper sanitation. * Minimize network exposure for all control system devices and systems and ensure that they are not accessible from the Internet. * When remote access is required, use secure methods, such as Virtual Private Networks (VPNs). Recognize that VPNs may have vulnerabilities and should be updated to the most current version available. Also, understand that VPNs are only as secure as the connected devices. For more information refer to the Schneider Electric [Recommended Cybersecurity Best Practices](https://www.se.com/us/en/download/document/7EN52-0390/) document.
For More Information
This document provides an overview of the identified vulnerability or vulnerabilities and actions required to mitigate. For more details and assistance on how to protect your installation, contact your local Schneider Electric representative or Schneider Electric Industrial Cybersecurity Services: https://www.se.com/ww/en/work/solutions/cybersecurity/. These organizations will be fully aware of this situation and can support you through the process. For further information related to cybersecurity in Schneider Electric's products, visit the company's cybersecurity support portal page: https://www.se.com/ww/en/work/support/cybersecurity/overview.jsp
LEGAL DISCLAIMER
About Schneider Electric
This ICSA is a verbatim republication of Schneider Electric CPCERT SEVD-2026-069-04 from a direct conversion of the vendor's Common Security Advisory Framework (CSAF) advisory. This is republished to CISA's website as a means of increasing visibility and is provided "as-is" for informational purposes only. CISA is not responsible for the editorial or technical accuracy of republished advisories and provides no warranties of any kind regarding any information contained within this advisory. Further, CISA does not endorse any commercial product or service. Please contact Schneider Electric CPCERT directly for any questions regarding this advisory.
  • Initial Release Date: 2026-03-10
2026-03-10 1 Original Release
2026-03-19 2 Initial CISA Republication of Schneider Electric CPCERT SEVD-2026-069-04 advisory
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-078-03
