Siemens Desigo CC Product Family and SENTRON Powermanager
Versions V6.0 through V8 QU1 of the Desigo CC product family (Desigo CC, Desigo CC Compact, Desigo CC Connect, Cerberus DMS), as well as the Desigo CC-based SENTRON Powermanager, are affected by a vulnerability in the underlying third-party component WIBU Systems CodeMeter Runtime. Successful exploitation of this vulnerability could lead to code execution in the context of the current process. Siemens has released instructions how to update the CodeMeter Runtime component and recommends to apply the update on affected systems.
The following versions of Siemens Desigo CC Product Family and SENTRON Powermanager are affected:
  • Desigo CC family V6 vers:all/* (CVE-2023-38545)
  • Desigo CC family V7 vers:all/* (CVE-2023-38545)
  • Desigo CC family V8: All versions prior to V8.0 QU2
  • SENTRON Powermanager V6 vers:all/* (CVE-2023-38545)
  • SENTRON Powermanager V7 vers:all/* (CVE-2023-38545)
  • SENTRON Powermanager V8: All versions prior to V8.0 QU2
v3 8.8 Siemens Siemens Desigo CC Product Family and SENTRON Powermanager Heap-based Buffer Overflow
CVE-2023-38545
This flaw makes curl overflow a heap based buffer in the SOCKS5 proxy handshake. When curl is asked to pass along the hostname to the SOCKS5 proxy to allow that to resolve the address instead of it getting done by curl itself, the maximum length that hostname can be is 255 bytes. If the hostname is detected to be longer than 255 bytes, curl switches to local name resolving and instead passes on the resolved address only to the proxy. Due to a bug, the local variable that means "let the host resolve the name" could get the wrong value during a slow SOCKS5 handshake, and contrary to the intention, copy the too long hostname to the target buffer instead of copying just the resolved address there.
Desigo CC family V6, Desigo CC family V7, Desigo CC family V8, SENTRON Powermanager V6, SENTRON Powermanager V7, SENTRON Powermanager V8
Update to V8.0 QU2 or later version
Apply patch as documented in section 'Additional Information'
Relevant CWE: CWE-122 Heap-based Buffer Overflow
3.1 8.8 HIGH CVSS:3.1/AV:N/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:H
This ICSA is a verbatim republication of Siemens ProductCERT SSA-507364 from a direct conversion of the vendor's Common Security Advisory Framework (CSAF) advisory. This is republished to CISA's website as a means of increasing visibility and is provided "as-is" for informational purposes only. CISA is not responsible for the editorial or technical accuracy of republished advisories and provides no warranties of any kind regarding any information contained within this advisory. Further, CISA does not endorse any commercial product or service. Please contact Siemens ProductCERT directly for any questions regarding this advisory.
  • Initial Release Date: 2026-02-10
2026-02-10 1 Publication Date
2026-02-12 2 Initial CISA Republication of Siemens ProductCERT SSA-507364 advisory
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-043-04
