Solid Edge uses PS/IGES Parasolid Translator Component that contains an out of bounds read that could be triggered when the application reads files in IGS file formats. If a user is tricked to open a malicious file with any of the affected products, this could lead the application to crash or potentially lead to arbitrary code execution. Siemens has released a new version for Solid Edge and recommends to update to the latest version.
The following versions of Siemens Solid Edge are affected:
  • Solid Edge: All versions prior to V226.00 Update 03
v3 7.8 Siemens Siemens Solid Edge Out-of-bounds Read
CVE-2025-40936
The affected applications contains an out of bounds read vulnerability while parsing specially crafted IGS files. This could allow an attacker to crash the application or execute code in the context of the current process. (ZDI-CAN-26755)
Siemens Solid Edge
Solid Edge
Update to V226.00 Update 03 or later version
  • Trend Micro Zero Day Initiative reported this vulnerability to Siemens.
This ICSA is a verbatim republication of Siemens ProductCERT SSA-445819 from a direct conversion of the vendor's Common Security Advisory Framework (CSAF) advisory. This is republished to CISA's website as a means of increasing visibility and is provided "as-is" for informational purposes only. CISA is not responsible for the editorial or technical accuracy of republished advisories and provides no warranties of any kind regarding any information contained within this advisory. Further, CISA does not endorse any commercial product or service. Please contact Siemens ProductCERT directly for any questions regarding this advisory.
  • Initial Release Date: 2026-02-10
2026-02-10 1 Publication Date
2026-02-12 2 Initial CISA Republication of Siemens ProductCERT SSA-445819 advisory
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-043-05
