Saltar al contenido principal
IT BIBLEIniciar sesión
Multiple Siemens products are affected by two local privilege escalation vulnerabilities which could allow an low privileged attacker to load malicious DLLs, potentially leading to arbitrary code execution with elevated privileges. Siemens has released new versions for the affected products and recommends to update to the latest versions.
The following versions of Siemens SINEC NMS are affected:
  • SINEC NMS: Versions prior to V4.0 SP2 (CVE-2026-25655)
  • SINEC NMS: All Versions (CVE-2026-25656)
  • User Management Component (UMC) vers:intdot/<2.15.2.1 (CVE-2026-25656)
v3 7.8 Siemens Siemens SINEC NMS Uncontrolled Search Path Element
  • Critical Infrastructure Sectors: Information Technology, Energy, Critical Manufacturing
CVE-2026-25655
The affected application permits improper modification of a configuration file by a low-privileged user. This could allow an attacker to load malicious DLLs, potentially leading to arbitrary code execution with administrative privilege.(ZDI-CAN-28107)
Siemens SINEC NMS
SINEC NMS
Update to V4.0 SP2 or later version
Relevant CWE: CWE-427 Uncontrolled Search Path Element
3.1 7.8 HIGH CVSS:3.1/AV:L/AC:L/PR:L/UI:N/S:U/C:H/I:H/A:H
CVE-2026-25656
The affected application permits improper modification of a configuration file by a low-privileged user. This could allow an attacker to load malicious DLLs, potentially leading to arbitrary code execution with SYSTEM privileges.(ZDI-CAN-28108)
Siemens SINEC NMS
SINEC NMS, User Management Component (UMC)
Update to V2.15.2.1 or later version
Update UMC to V2.15.2.1 or later compatible version https://support.industry.siemens.com/cs/document/109996127/
  • Siemens ProductCERT reported these vulnerabilities to CISA.
  • Trend Micro Zero Day Initiative reported these vulnerabilities to Siemens.
This ICSA is a verbatim republication of Siemens ProductCERT SSA-311973 from a direct conversion of the vendor's Common Security Advisory Framework (CSAF) advisory. This is republished to CISA's website as a means of increasing visibility and is provided "as-is" for informational purposes only. CISA is not responsible for the editorial or technical accuracy of republished advisories and provides no warranties of any kind regarding any information contained within this advisory. Further, CISA does not endorse any commercial product or service. Please contact Siemens ProductCERT directly for any questions regarding this advisory.
  • Initial Release Date: 2026-02-10
2026-02-10 1 Publication Date
2026-02-12 2 Initial CISA Republication of Siemens ProductCERT SSA-311973 advisory
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-043-01
