Avation Light Engine Pro
Successful exploitation of this vulnerability could allow an attacker to take full control of the device.
The following versions of Avation Light Engine Pro are affected:
  • Light Engine Pro vers:all/* (CVE-2026-1341)
v3 9.8 Avation Avation Light Engine Pro Missing Authentication for Critical Function
  • Critical Infrastructure Sectors: Commercial Facilities
  • Company Headquarters Location: Australia
CVE-2026-1341
Avation Light Engine Pro exposes its configuration and control interface without any authentication or access control.
Avation
Avation Light Engine Pro: vers:all/*
Avation has not responded to CISA's request to coordinate. Users of Avation Light Engine Pro are encouraged to contact Avation for more information.
  • Souvik Kandar reported this vulnerability to CISA
  • Initial Release Date: 2026-02-03
2026-02-03 1 Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-034-02
