Saltar al contenido principal
IT BIBLEIniciar sesión
Rockwell Automation ControlLogix
Successful exploitation of this vulnerability could allow an attacker to cause a denial-of-service condition.
The following versions of Rockwell Automation ControlLogix are affected:
  • ControlLogix Redundancy Enhanced Module Catalog 1756-RM2 Firmware vers:all/* (CVE-2025-14027)
  • ControlLogix Redundancy Enhanced Module Catalog 1756-RM2XT Firmware vers:all/* (CVE-2025-14027)
v3 7.5 Rockwell Automation Rockwell Automation ControlLogix Missing Release of Memory after Effective Lifetime
  • Critical Infrastructure Sectors: Chemical, Energy, Critical Manufacturing, Food and Agriculture, Transportation Systems, Water and Wastewater
CVE-2025-14027
Multiple denial-of-service issues exist in 1756-RM2 and 1756-RM2XT firmware (ControlLogix Redundancy Enhanced Modules). These issues can be triggered through various crafted inputs, including malformed Class 3 messages, memory leak conditions, and other resource exhaustion scenarios. Exploitation may cause the device to become unresponsive and, in some cases, result in a major nonrecoverable fault. Recovery may require a restart.
Rockwell Automation
Rockwell Automation ControlLogix Redundancy Enhanced Module Catalog 1756-RM2 Firmware: vers:all/*, Rockwell Automation ControlLogix Redundancy Enhanced Module Catalog 1756-RM2XT Firmware: vers:all/*
Rockwell Automation recommends that users upgrade from the 1756-RM2 to 1756-RM3.
If users are unable to upgrade to the 1756-RM3, security best practices should be applied.
See Rockwell Automation's SD1769 advisory for more information.
Relevant CWE: CWE-401 Missing Release of Memory after Effective Lifetime
  • Rockwell Automation reported this vulnerability to CISA
  • Initial Release Date: 2026-01-29
2026-01-29 1 Initial Republication of Rockwell Automation advisory SD1769
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-029-03
