Schneider Electric Zigbee Products
Schneider Electric is aware of multiple vulnerabilities with EmberZNet disclosed by Silicon Labs. Many vendors, including Schneider Electric, use Silicon Labs’ Zigbee processors in their offers. The following have denial of service vulnerabilities: Wiser iTRV, Wiser RTR, Wiser UFH, Wiser Heat Switch, Wiser Boiler Relay, cFMT (Exaact, Elko, Odace, Merten), Wiser Micromodule, Iconic Wiser Connected Smart Dimmer, Iconic Zigbee devices, Wiser Application Modules, Wiser Connected Pushbutton Switch/Dimmer/Shutter controller, Rotary Dimmer, Motion Sensor Dimmer/Switch, Smart socket outlets, and EV socket outlet. See the following table. Failure to apply the mitigations provided below may risk denial of service, which could result in products being unavailable.
The following versions of Schneider Electric Zigbee Products are affected:
  • Wiser iTRV2 (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
  • Wiser iTRV3 (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
  • Wiser RTR2 (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
  • Wiser UFH (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
  • Wiser 16A Electrical Heat Switch (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
  • Wiser Boiler Relay (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
  • Exxact cFMT 16a (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
  • Elko cFMT 16a (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
  • Odace cFMT 2a (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
  • Merten cFMT 16a (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
  • Merten cFMT 2a (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
  • Wiser Power Micromodule (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
  • Wiser FIP Micromodule (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
  • Iconic, Wiser Connected Smart Dimmer (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
  • Iconic, Wiser Connected Smart Switch, 2AX (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
  • Iconic, Wiser Connected Smart Switch, 10AX (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
  • Iconic, Connected AC Fan Controller (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
  • Iconic, Connected Smart Socket (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
  • Wiser Connected Application Module 1-Gang (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
  • Wiser Connected Application Module 2-Gang (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
  • Wiser Connected Push Button Dimmer (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
  • Wiser Connected Push Button Switch (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
  • Wiser Connected Push Button Shutter (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
  • Wiser Connected Motion Dimmer (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
  • Wiser Connected Motion Switch (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
  • Wiser Connected Rotary Dimmer (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
  • Connected Wireless Switch (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
  • Micromodule Switch (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
  • Micromodule Dimmer (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
  • Micromodule Shutter (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
  • Connected Single Socket Outlet (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
  • Connected Double Socket Outlet (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
  • Fuga Connected Socket Outlet (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
  • Mureva EV Link (CVE-2024-6350, CVE-2024-6351, CVE-2024-6352, CVE-2024-10106, CVE-2024-7322)
v3 6.5 Schneider Electric Schneider Electric Zigbee Products Buffer Copy without Checking Size of Input ('Classic Buffer Overflow'), Uncontrolled Resource Consumption
  • Critical Infrastructure Sectors: Commercial Facilities, Critical Manufacturing, Energy, Information Technology, Transportation Systems
CVE-2024-6350
A CWE-120: A buffer overflow vulnerability exists that could cause a denial of service when a malicious device joins the network.
Schneider Electric
Wiser iTRV2 All Versions, Wiser iTRV3 All Versions, Wiser RTR2 All Versions, Wiser UFH All Versions, Wiser 16A Electrical Heat Switch All Versions, Wiser Boiler Relay All Versions, Exxact cFMT 16a All Versions, Elko cFMT 16a All Versions, Odace cFMT 2a All Versions, Merten cFMT 16a All Versions, Merten cFMT 2a All Versions, Wiser Power Micromodule All Versions, Wiser FIP Micromodule All Versions, Iconic, Wiser Connected Smart Dimmer All Versions, Iconic, Wiser Connected Smart Switch, 2AX All Versions, Iconic, Wiser Connected Smart Switch, 10AX All Versions, Iconic, Connected AC Fan Controller All Versions, Iconic, Connected Smart Socket All Versions, Wiser Connected Application Module 1-Gang All Versions, Wiser Connected Application Module 2-Gang All Versions, Wiser Connected Push Button Dimmer All Versions, Wiser Connected Push Button Switch All Versions, Wiser Connected Push Button Shutter All Versions, Wiser Connected Motion Dimmer All Versions, Wiser Connected Motion Switch All Versions, Wiser Connected Rotary Dimmer All Versions, Connected Wireless Switch All Versions, Micromodule Switch All Versions, Micromodule Dimmer All Versions, Micromodule Shutter All Versions, Connected Single Socket Outlet All Versions, Connected Double Socket Outlet All Versions, Fuga Connected Socket Outlet All Versions, Mureva EV Link All Versions
Customers should immediately apply the following mitigations to reduce the risk of exploit: To keep your Zigbee network safe and prevent unauthorized access: • Restrict device access: Do not allow unknown devices to join your network. • Review hub settings: Check how your Zigbee hub manages device pairing. • Control network availability: Only open the network when adding new devices and close it immediately after. • Use install codes and avoid the well-known key: Whenever possible, use unique install codes for added security. Replace default keys with secure, unique keys.
Relevant CWE: CWE-120 Buffer Copy without Checking Size of Input ('Classic Buffer Overflow')
3.1 6.5 MEDIUM CVSS:3.1/AV:A/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:H
CVE-2024-6351
Schneider Electric
3.1 4.3 MEDIUM CVSS:3.1/AV:A/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:L
CVE-2024-6352
Schneider Electric
CVE-2024-10106
Schneider Electric
3.1 3.7 LOW CVSS:3.1/AV:N/AC:H/PR:N/UI:N/S:U/C:N/I:N/A:L
CVE-2024-7322
A CWE-400: Uncontrolled Resource Consumption vulnerability exists that could cause a denial of service when a malicious device joins the network.
Schneider Electric
Relevant CWE: CWE-400 Uncontrolled Resource Consumption
3.1 5.8 MEDIUM CVSS:3.1/AV:N/AC:H/PR:H/UI:N/S:C/C:N/I:N/A:H
  • Schneider Electric CPCERT reported these vulnerabilities to CISA.
  • Silicon Labs reported these vulnerabilities to Schneider Electric
We strongly recommend the following industry cybersecurity best practices. https://www.se.com/us/en/download/document/7EN52-0390/ * Locate control and safety system networks and remote devices behind firewalls and isolate them from the business network. * Install physical controls so no unauthorized personnel can access your industrial control and safety systems, components, peripheral equipment, and networks. * Place all controllers in locked cabinets and never leave them in the “Program” mode. * Never connect programming software to any network other than the network intended for that device. * Scan all methods of mobile data exchange with the isolated network such as CDs, USB drives, etc. before use in the terminals or any node connected to these networks. * Never allow mobile devices that have connected to any other network besides the intended network to connect to the safety or control networks without proper sanitation. * Minimize network exposure for all control system devices and systems and ensure that they are not accessible from the Internet. * When remote access is required, use secure methods, such as Virtual Private Networks (VPNs). Recognize that VPNs may have vulnerabilities and should be updated to the most current version available. Also, understand that VPNs are only as secure as the connected devices. For more information refer to the Schneider Electric Recommended Cybersecurity Best Practices document.
For More Information
This document provides an overview of the identified vulnerability or vulnerabilities and actions required to mitigate. For more details and assistance on how to protect your installation, contact your local Schneider Electric representative or Schneider Electric Industrial Cybersecurity Services: https://www.se.com/ww/en/work/solutions/cybersecurity/. These organizations will be fully aware of this situation and can support you through the process. For further information related to cybersecurity in Schneider Electric’s products, visit the company’s cybersecurity support portal page: https://www.se.com/ww/en/work/support/cybersecurity/overview.jsp
LEGAL DISCLAIMER
About Schneider Electric
At Schneider, we believe access to energy and digital is a basic human right. We empower all to do more with less, ensuring Life Is On everywhere, for everyone, at every moment. We provide energy and automation digital solutions for efficiency and sustainability. We combine world-leading energy technologies, real-time automation, software and services into integrated solutions for Homes, Buildings, Data Centers, Infrastructure and Industries. We are committed to unleash the infinite possibilities of an open, global, innovative community that is passionate with our Meaningful Purpose, Inclusive and Empowered values. www.se.com
Vulnerability Details
These vulnerabilities disclosed by Silicon Labs affect their Zigbee processors, which are used in multiple Schneider Electric's products.
This ICSA is a verbatim republication of Schneider Electric CPCERT SEVD-2026-013-03 from a direct conversion of the vendor's Common Security Advisory Framework (CSAF) advisory. This is republished to CISA's website as a means of increasing visibility and is provided "as-is" for informational purposes only. CISA is not responsible for the editorial or technical accuracy of republished advisories and provides no warranties of any kind regarding any information contained within this advisory. Further, CISA does not endorse any commercial product or service. Please contact Schneider Electric CPCERT directly for any questions regarding this advisory.
  • Initial Release Date: 2026-01-13
2026-01-13 1 Original Release
2026-01-27 2 Initial Republication of Schneider Electric CPCERT SEVD-2026-013-03 advisory
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-027-03
