Columbia Weather Systems MicroServer
Successful exploitation of these vulnerabilities could allow an attacker to redirect connections to an attacker controlled device, gain admin access to the web portal, or gain limited shell access.
The following versions of Columbia Weather Systems MicroServer are affected:
  • MicroServer firmware (CVE-2025-61939, CVE-2025-64305, CVE-2025-66620)
v3 8.8 Columbia Weather Systems Columbia Weather Systems MicroServer Improper Restriction of Communication Channel to Intended Endpoints, Cleartext Storage in a File or on Disk, Command Shell in Externally Accessible Directory
  • Critical Infrastructure Sectors: Information Technology
  • Countries/Areas Deployed: United States
CVE-2025-61939
An unused function in the MicroServer can start a reverse ssh connection to a vendor registered domain, without mutual authentication. An attacker on the local network with admin access to the web server, and the ability to manipulate DNS responses, can redirect the SSH connection to an attacker controlled device.
Columbia Weather Systems MicroServer firmware:
Columbia Weather Systems recommends users update the MicroServer firmware to version MS_4.1_14142 or later. To obtain the update, users should contact Columbia Weather Systems Support directly via email ([email protected]) or phone (503-629-0887) for assistance.
Relevant CWE: CWE-923 Improper Restriction of Communication Channel to Intended Endpoints
CVE-2025-64305
The MicroServer copies parts of the system firmware to an unencrypted external SD card on boot, which contains user and vendor secrets. An attacker can utilize these plaintext secrets to modify the vendor firmware, or gain admin access to the web portal.
Relevant CWE: CWE-313 Cleartext Storage in a File or on Disk
3.1 6.5 MEDIUM CVSS:3.1/AV:A/AC:L/PR:N/UI:N/S:U/C:H/I:N/A:N
CVE-2025-66620
An unused webshell in the MicroServer allows unlimited login attempts, with sudo rights on certain files and directories. An attacker with admin access to the MicroServer can gain limited shell access, enabling persistence through reverse shells, and the ability to modify or remove data stored in the file system.
Relevant CWE: CWE-553 Command Shell in Externally Accessible Directory
3.1 8 HIGH CVSS:3.1/AV:A/AC:L/PR:L/UI:N/S:U/C:H/I:H/A:H
  • UsrPacific/Columbia Weather Systems reported these vulnerabilities to CISA
  • Initial Release Date: 2025-01-06
2026-01-06 1 Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-006-01
