Zum Hauptinhalt springen
IT BIBLEAnmelden
Rockwell Automation Micro820, Micro850, Micro870
Successful exploitation of these vulnerabilities could result in a denial-of-service condition.
The following versions of Rockwell Automation Micro820, Micro850, Micro870 are affected:
  • Micro820 (CVE-2025-13823, CVE-2025-13824)
v3 7.5 Rockwell Automation Rockwell Automation Micro820, Micro850, Micro870 Dependency on Vulnerable Third-Party Component, Release of Invalid Pointer or Reference
CVE-2025-13823
A security issue was found in the IPv6 stack in the Micro850 and Micro870 controllers. This issue occurs when the controllers received multiple malformed packets during fuzzing, causing a recoverable fault.
Rockwell Automation
Rockwell Automation Micro820: <=V14.011
Rockwell Automation recommends users of Micro820 V14.011 and prior update to newer Micro820 controllers (L20E V23.011 or later).
Rockwell Automation recommends users of Micro850/870 update to V12.013 or later. The update can be downloaded from the Rockwell Automation website.
For CVE-2025-13823, Rockwell Automation advises users to disable IPv6 functionalities if they do not require the feature.
Rockwell Automation users using the affected software, who are not able to upgrade to one of the corrected versions, should follow Rockwell Automation's security best practices.
For more information, please review Rockwell Automation's advisory.
Relevant CWE: CWE-1395 Dependency on Vulnerable Third-Party Component
3.1 6.5 MEDIUM CVSS:3.1/AV:A/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:H
CVE-2025-13824
A security issue exists due to improper handling of malformed CIP packets during fuzzing. The controller enters a hard fault with a solid red Fault LED and becomes unresponsive. Upon power cycling, the controller will enter a recoverable fault.
Rockwell Automation
Relevant CWE: CWE-763 Release of Invalid Pointer or Reference
  • Rockwell Automation reported these vulnerabilities to CISA
  • Initial Release Date: 2025-12-18
2025-12-18 1 Initial Republication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-352-07
Anmelden um zu antworten.
