Johnson Controls PowerG, IQPanel and IQHub
Successful exploitation of these vulnerabilities could allow an attacker to read or write encrypted traffic or perform a replay attack.
The following versions of Johnson Controls PowerG, IQPanel and IQHub are affected:
  • PowerG (CVE-2025-61738, CVE-2025-61739, CVE-2025-26379, CVE-2025-61740)
  • IQHub (CVE-2025-61738, CVE-2025-61739, CVE-2025-26379, CVE-2025-61740)
  • IQPanel 2 (CVE-2025-61738, CVE-2025-61739, CVE-2025-26379, CVE-2025-61740)
  • IQPanel 2+ (CVE-2025-61738, CVE-2025-61739, CVE-2025-26379, CVE-2025-61740)
  • IQPanel 4 (CVE-2025-61738, CVE-2025-61739, CVE-2025-26379, CVE-2025-61740)
v3 7.6 Johnson Controls Inc. Johnson Controls PowerG, IQPanel and IQHub Cleartext Transmission of Sensitive Information, Reusing a Nonce, Key Pair in Encryption, Use of Cryptographically Weak Pseudo-Random Number Generator (PRNG), Origin Validation Error
  • Critical Infrastructure Sectors: Commercial Facilities
  • Company Headquarters Location: Ireland
CVE-2025-61738
The affected product is vulnerable due to cleartext transmission of sensitive information. This may allow an attacker to capture the network key and read or write encrypted packets on the PowerG network.
Johnson Controls Inc. PowerG: <=53.02, Johnson Controls Inc. IQHub: vers:all/*, Johnson Controls Inc. IQPanel 2: vers:all/*, Johnson Controls Inc. IQPanel 2+: vers:all/*, Johnson Controls Inc. IQPanel 4: <4.6.1
Johnson Controls recommends the following:
Update IQPanel 4 to version 4.6.1/4.6.1i.
Devices that support PowerG+ should use PowerG v53.05 or later.
During the installation or enrollment phase of setup, enter the PIN code in the PIN Code field on the sensor enrollment screen. For additional security, Johnson Controls recommends only authorized company personnel or integrators be present during the pairing process.
Replace all end-of-life products (IQ Panel 2, IQ Panel 2+, IQ Hub) with the latest IQ Panel 4 using firmware version 4.6.1 or greater.
For more detailed mitigation instructions, see Johnson Controls Product Security Advisory JCI-PSA-2025-01 at the Product Security Advisories page.
3.1 5.3 MEDIUM CVSS:3.1/AV:N/AC:H/PR:N/UI:R/S:U/C:H/I:N/A:N
CVE-2025-61739
The affected product is vulnerable due to nonce reuse, which may allow an attacker to perform a replay attack or decrypt captured packets.
Relevant CWE: CWE-323 Reusing a Nonce, Key Pair in Encryption
3.1 7.6 HIGH CVSS:3.1/AV:A/AC:L/PR:N/UI:N/S:U/C:L/I:H/A:L
CVE-2025-26379
The affected product is vulnerable due to a weak pseudo-random number generator. This may allow an attacker to read or inject encrypted PowerG packets.
Relevant CWE: CWE-338 Use of Cryptographically Weak Pseudo-Random Number Generator (PRNG)
CVE-2025-61740
The affected product is vulnerable to an authentication issue that does not verify the source of a packet. This could allow an attacker to create a denial-of-service condition or modify the configuration of the device.
Relevant CWE: CWE-346 Origin Validation Error
  • James Chambers and Sultan Qasim Khan of NCC Group reported these vulnerabilities to CISA.
No known public exploitation specifically targeting these vulnerabilities have been reported to CISA at this time.
  • Initial Release Date: 2025-12-16
2025-12-16 1 Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-350-02
