Mitsubishi Electric GT Designer3
Successful exploitation of this vulnerability could allow an attacker obtain plaintext credentials from the project file for GT Designer3, which could result in illegally operating GOT2000 and GOT1000 series devices.
The following versions of Mitsubishi Electric GT Designer3 are affected:
  • GT Designer3 Version1 (GOT2000) (CVE-2025-11009)
  • GT Designer3 Version1 (GOT1000) (CVE-2025-11009)
v3 5.1 Mitsubishi Electric Mitsubishi Electric GT Designer3 Cleartext Storage of Sensitive Information
  • Company Headquarters Location: Japan
CVE-2025-11009
Information Disclosure vulnerability due to Cleartext Storage of Sensitive Information(CWE-312) exists in GT Designer3. GT Designer3 stores credentials and verifies them in plain text, therefore an attacker may be able to obtain plaintext credentials from the project file for GT Designer3. As a result, the attacker may be able to operate illegally GOT2000 series or GOT1000 series by using the obtained credentials.
Mitsubishi Electric
Mitsubishi Electric GT Designer3 Version1 (GOT2000): vers:all/*, Mitsubishi Electric GT Designer3 Version1 (GOT1000): vers:all/*
Mitsubishi Electric recommends that users take the following mitigation measures to minimize the risk of exploiting this vulnerability:
Use a personal computer with the affected product within the LAN and block remote login from untrusted networks, hosts, and users.
When connecting a personal computer with the affected product to the Internet, use a firewall, virtual private network (VPN), etc., to prevent unauthorized access and allow only trusted users to remote login.
Install an antivirus software on the computer using the affected product.
Don't open untrusted files or click untrusted links.
For more information, see Mitsubishi Electric's security advisory.
Relevant CWE: CWE-312 Cleartext Storage of Sensitive Information
3.1 5.1 MEDIUM CVSS:3.1/AV:L/AC:H/PR:N/UI:N/S:U/C:H/I:N/A:N
  • Hea-Eun Moon and Junbeom Gwak of Red Alert Lab at NSHC reported this vulnerability to Mitsubishi Electric
No known public exploitation specifically targeting this vulnerability has been reported to CISA at this time. This vulnerability is not exploitable remotely. This vulnerability has a high attack complexity.
  • Initial Release Date: 2025-12-16
2025-12-16 1 Initial Republication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-350-04
