Sunbird DCIM dcTrack and Power IQ
  • CVSS v4 8.4
  • Vendor: Sunbird
  • Equipment: DCIM dcTrack, Power IQ
  • Vulnerabilities: Authentication Bypass Using an Alternate Path or Channel, Use of Hard-coded Credentials
Successful exploitation of these vulnerabilities could allow an attacker to gain unauthorized access or steal credentials.
The following Sunbird products are affected:
  • DCIM dcTrack: Versions v9.2.0 and prior
  • Power IQ: Versions v9.2.0 and prior
3.2 Vulnerability Overview
3.2.1 Authentication Bypass Using an Alternate Path or Channel CWE-288
DCIM dcTrack allows an attacker to misuse certain remote access features. An authenticated user with access to the appliance's virtual console could exploit these features to redirect network traffic, potentially accessing restricted services or data on the host machine.
CVE-2025-66238 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.5 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:H/UI:N/S:U/C:H/I:H/A:N).
A CVSS v4 score has also been calculated for CVE-2025-66238. A base score of 7.4 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:P/PR:H/UI:N/VC:H/VI:H/VA:N/SC:N/SI:N/SA:N).
3.2.2 Use of Hard-coded Credentials CWE-798
DCIM dcTrack platforms utilize default and hard-coded credentials for access. An attacker could use these credentials to administer the database, escalate privileges on the platform or execute system commands on the host.
CVE-2025-66237 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.7 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:H/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-66237. A base score of 8.4 has been calculated; the CVSS vector string is (AV:L/AC:L/AT:N/PR:H/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Information Technology, Critical Manufacturing
notnotnotveg ([email protected]) reported these vulnerabilities to CISA.
Sunbird recommends that users take the following actions:
  • dcTrack: Update to 9.2.3
  • Power: Update to IQ 9.2.1
If updating immediately is not possible, Sunbird additionally recommends that customers:
  • Restrict SSH or any non-essential port access in the IP Based Access Control.
  • Passwords for SSH based user accounts be changed at the time of deployment.
  • December 4, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-338-05
