Johnson Controls iSTAR
  • CVSS v4 7.1
  • Vendor: Johnson Controls Inc.
  • Equipment: iSTAR eX, iSTAR Edge, iSTAR Ultra LT, iSTAR Ultra, iSTAR Ultra SE
  • Vulnerability: Improper Validation of Certificate Expiration
Successful exploitation of this vulnerability could result in the product failing to re-establish communication once the certificate expires.
The following versions of Johnson Controls iSTAR are affected:
  • iSTAR eX: All versions prior to TLS 1.2
  • iSTAR Edge: All versions prior to TLS 1.2
  • iSTAR Ultra LT (if in TLS 1.2): All versions prior to TLS 1.2
  • iSTAR Ultra (if in TLS 1.2): All versions prior to TLS 1.2
  • iSTAR Ultra SE (if in TLS 1.2): All versions prior to TLS 1.2
3.2.1 IMPROPER VALIDATION OF CERTIFICATE EXPIRATION CWE-298
Under certain circumstances, an iSTAR using the default certificate to connect to the C•CURE Server may fail to re-establish communication, once the certificate expires.
CVE-2025-61736 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.5 has been calculated; the CVSS vector string is (AV:A/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:H).
A CVSS v4 score has also been calculated for CVE-2025-61736. A base score of 7.1 has been calculated; the CVSS vector string is (AV:A/AC:L/AT:N/PR:N/UI:N/VC:N/VI:N/VA:H/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Commercial Facilities, Critical Manufacturing, Energy, Government Facilities, Transportation Systems
Johnson Controls reported this vulnerability to CISA.
Johnson Controls recommends the following mitigations:
Host-based certificates using TLS 1.2:
  • Quickest solution
  • No Upgrade required to specific C•CURE or iSTAR software/firmware versions
  • Requires downloading a new certificate to all iSTAR panels simultaneously, resulting in a brief system downtime
Convert encryption mode to TLS 1.3, per cluster:
  • Requires firmware 6.9.0 or higher, and C•CURE 9000 v2.90 SP3 or higher
  • Enables phased implementation by cluster, minimizing disruption
  • Note: TLS 1.3 is not supported on iSTAR eX, iSTAR Edge, and iSTAR Ultra LT panels
Upgrade legacy panels to new G2 hardware:
  • Recommended for smaller systems due to time constraints
  • Applies primarily to iSTAR eX, iSTAR Edge, and iSTAR LT panels
Johnson Controls strongly encourages users to work with their Software House integrators to audit their systems and determine the most appropriate course of action. Johnson Control's technical support team provides extensive documentation and instructional videos on the Support Portal, and hosts ongoing webinars covering both host-based certificate implementation and TLS 1.3 migration.
For more detailed mitigation instructions, please see Johnson Controls Product Security Advisory JCI-PSA-2025-12 at the following location: https://www.johnsoncontrols.com/trust-center/cybersecurity/security-advisories
  • December 04, 2025: Initial Republication of JCI-PSA-2025-12
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-338-04
