Mitsubishi Electric GX Works2
  • CVSS v4 6.8
  • Vendor: Mitsubishi Electric
  • Equipment: GX Works2
  • Vulnerability: Cleartext Storage of Sensitive Information
Successful exploitation of this vulnerability could open project files protected by user authentication using disclosed credential information, and obtain or modify project information.
The following versions of GX Works2 are affected:
  • GX Works2: All versions
3.2.1 CLEARTEXT STORAGE OF SENSITIVE INFORMATION CWE-312
An attacker could disclose credential information stored in plaintext from project files. As a result, the attacker may be able to open project files protected by user authentication using disclosed credential information, and obtain or modify project information.
CVE-2025-3784 has been assigned to this vulnerability. A CVSS v3.1 base score of 5.5 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:L/UI:N/S:U/C:H/I:N/A:N).
A CVSS v4 score has also been calculated for CVE-2025-3784. A base score of 6.8 has been calculated; the CVSS vector string is (AV:L/AC:L/AT:N/PR:L/UI:N/VC:H/VI:N/VA:N/SC:N/SI:N/SA:N).
Jiho Shin of Sungkyunkwan University reported this vulnerability to Mitsubishi Electric. Mitsubishi Electric reported this vulnerability to CISA.
The fixed version for this vulnerability is currently under development by Mitsubishi Electric. Until the fixed version is released, please implement the following mitigations:
  • Use the PCs with the affected product installed in the LAN and block remote logins from untrusted networks, hosts, or users.
  • Block unauthorized access by using a firewall or a virtual private network (VPN), etc., and allow remote logins only for trusted users when connecting the PCs with the affected product installed to the Internet.
  • Restrict physical access to the PCs with the affected product installed, as well as to PCs and network devices that can communicate with those PCs.
  • Install an antivirus software on the PCs running the affected product.
  • Encrypt project files when sending or receiving them over the Internet.
See Mitsubishi Electric's security bulletin for information on the availability of the security updates.
  • December 4, 2025: Initial Republication of Mitsubishi Electric Advisory Mitsubishi Electric 2025-016
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-338-01
