Zum Hauptinhalt springen
IT BIBLEAnmelden
Rockwell Automation Arena Simulation
  • CVSS v4 7.1
  • ATTENTION: Exploitable from a local network
  • Equipment: Arena Simulation
Successful exploitation of this vulnerability could allow local attackers to execute arbitrary code on affected installations of Arena.
The following Rockwell Automation products are affected:
  • Arena Simulation: Version 16.20.10 and prior
Arena suffers from a stack-based buffer overflow vulnerability. The specific flaw exists within the parsing of DOE files. Local attackers are able to exploit this issue to potentially execute arbitrary code on affected installations of Arena. Exploiting the vulnerability requires opening a malicious DOE file.
CVE-2025-11918 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.0 has been calculated; the CVSS vector string is (AV:L/AC:H/PR:N/UI:R/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-11918. A base score of 7.1 has been calculated; the CVSS vector string is (AV:L/AC:H/AT:N/PR:N/UI:A/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
Michael Heinzl reported this vulnerability to CISA.
Rockwell Automation recommends users upgrade Arena Simulation to version 16.20.11 or later.
Users who are unable to upgrade the affected software to a correct version should use Rockwell Automation's security best practices.
For more information about this issue, see advisory SD1763 on the Rockwell Automation security page.
  • November 25, 2025: Initial publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-329-02
Anmelden um zu antworten.
