Emerson Appleton UPSMON-PRO
  • CVSS v4 9.3
  • Vendor: Emerson
  • Equipment: Appleton UPSMON-PRO
Successful exploitation of this vulnerability could allow remote attackers to execute arbitrary code on affected installations of Appleton UPSMON-PRO.
The following Emerson products are affected:
  • Appleton UPSMON-PRO: Versions 2.6 and prior
A crafted UDP packet sent to the default UDP port 2601 can cause an overflow of the buffer stack, overwriting critical memory locations. This could allow unauthorized individuals to execute arbitrary code with SYSTEM privileges if the UPSMONProService service communication is not properly validated.
CVE-2024-3871 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.8 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2024-3871. A base score of 9.3 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Critical Manufacturing, Healthcare and Public Health
kimiya working with Trend Micro's Zero Day Initiative reported this vulnerability to CISA.
According to Emerson, Appleton UPSMON-PRO is End of Life and unsupported. Any users still using the product are recommended to replace the product or apply the following mitigations based on your company policies and Cybersecurity Operational recommendations.
Recommended Actions if not replaced:
  • Block UDP port 2601 at firewall level for all UPSMON-PRO installations
  • Isolate UPS monitoring networks from general corporate networks
  • Implement network-level packet filtering to reject oversized UDP packets to port 2601
  • Monitor for UPSMONProSer.exe service crashes as potential indicators of exploitation attempts
Long-term Strategy Recommendation:
  • Replace UPSMON-PRO with actively supported UPS monitoring solution
  • Implement defense-in-depth strategies for critical power infrastructure monitoring
  • November 20, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-324-06
