Brightpick Mission Control / Internal Logic Control
  • Vendor: Brightpick AI
  • Equipment: Brightpick Mission Control / Internal Logic Control
  • Vulnerabilities: Missing Authentication for Critical Function, Unprotected Transport of Credentials
Successful exploitation of these vulnerabilities could result in the exposure of sensitive information and the manipulation of critical functions by an attacker.
The following versions of Brightpick AI's warehouse automation platform, are affected:
  • Brightpick Mission Control / Internal Logic Control: All versions
The Brightpick Internal Logic Control web interface is accessible without requiring user authentication. An unauthorized user could exploit this interface to manipulate robot control functions, including initiating or halting runners, assigning jobs, clearing stations, and deploying storage totes.
CVE-2025-64307 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.5 has been calculated; the CVSS vector string is (AV:A/AC:L/PR:N/UI:N/S:U/C:N/I:H/A:N).
A CVSS v4 score has also been calculated for CVE-2025-64307. A base score of 7.1 has been calculated; the CVSS vector string is (CVSS:4.0/AV:A/AC:L/AT:N/PR:N/UI:N/VC:N/VI:H/VA:N/SC:N/SI:N/SA:N).
3.2.2 UNPROTECTED TRANSPORT OF CREDENTIALS CWE-523
The Brightpick Mission Control web application exposes hardcoded credentials in its client-side JavaScript bundle.
CVE-2025-64308 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.5 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:N/A:N).
A CVSS v4 score has also been calculated for CVE-2025-64308. A base score of 8.7 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:N/VA:N/SC:N/SI:N/SA:N).
3.2.3 UNPROTECTED TRANSPORT OF CREDENTIALS CWE-523
The affected product discloses device telemetry, configuration, and credential information via WebSocket traffic to unauthenticated users when they connect to a specific URL. The unauthenticated URL can be discovered through basic network scanning techniques.
CVE-2025-64309 has been assigned to this vulnerability. A CVSS v3.1 base score of 8.6 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:C/C:H/I:N/A:N).
A CVSS v4 score has also been calculated for CVE-2025-64309. A base score of 8.2 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:P/PR:N/UI:N/VC:H/VI:N/VA:N/SC:L/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Commercial Facilities, Critical Manufacturing, Healthcare and Public Health
  • COMPANY HEADQUARTERS LOCATION: Slovakia
Souvik Kandar reported these vulnerabilities to CISA.
Brightpick AI has not responded to requests to work with CISA to mitigate these vulnerabilities. Users of the affected products are encouraged to contact Brightpick AI for additional information.
  • November 13, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-317-04
