  • Equipment: Solid Edge
  • Vulnerability: Improper Certificate Validation
Successful exploitation of this vulnerability could allow an unauthenticated remote attacker to perform man in the middle attacks.
  • Siemens Solid Edge SE2025: All versions prior to V225.0 Update 11
3.2.1 IMPROPER CERTIFICATE VALIDATION CWE-295
Affected applications do not properly validate client certificates to connect to License Service endpoint. This could allow an unauthenticated remote attacker to perform man in the middle attacks.
CVE-2025-40744 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.5 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:N/A:N).
A CVSS v4 score has also been calculated for CVE-2025-40744. A base score of 8.7 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:N/VA:N/SC:N/SI:N/SA:N).
For more information see the associated Siemens security advisory SSA-522291 in HTML and CSAF.
  • November 13, 2025: Initial Republication of Siemens ProductCERT SSA-522291
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-317-14
