Mitsubishi Electric MELSEC iQ-F Series
  • CVSS v3 5.3
  • Vendor: Mitsubishi Electric
  • Equipment: MELSEC iQ-F Series
  • Vulnerability: Improper Validation of Specified Quantity in Input
Successful exploitation of this vulnerability could allow an attacker to cause a denial-of-service condition on the product.
The following versions of Mitsubishi Electric MELSEC iQ-F Series are affected:
  • FX5U-32MT/ES: All versions
  • FX5U-32MT/DS: All versions
  • FX5U-32MT/ESS: All versions
  • FX5U-32MT/DSS: All versions
  • FX5U-64MT/ES: All versions
  • FX5U-64MT/DS: All versions
  • FX5U-64MT/ESS: All versions
  • FX5U-64MT/DSS: All versions
  • FX5U-80MT/ES: All versions
  • FX5U-80MT/DS: All versions
  • FX5U-80MT/ESS: All versions
  • FX5U-80MT/DSS: All versions
  • FX5U-32MR/ES: All versions
  • FX5U-32MR/DS: All versions
  • FX5U-64MR/ES: All versions
  • FX5U-64MR/DS: All versions
  • FX5U-80MR/ES: All versions
  • FX5U-80MR/DS: All versions
  • FX5UC-32MT/D: All versions
  • FX5UC-32MT/DSS: All versions
  • FX5UC-64MT/D: All versions
  • FX5UC-64MT/DSS: All versions
  • FX5UC-96MT/D: All versions
  • FX5UC-96MT/DSS: All versions
  • FX5UC-32MT/DS-TS: All versions
  • FX5UC-32MT/DSS-TS: All versions
  • FX5UC-32MR/DS-TS: All versions
  • FX5UJ-24MT/ES: All versions
  • FX5UJ-24MT/DS: All versions
  • FX5UJ-24MT/ESS: All versions
  • FX5UJ-24MT/DSS: All versions
  • FX5UJ-40MT/ES: All versions
  • FX5UJ-40MT/DS: All versions
  • FX5UJ-40MT/ESS: All versions
  • FX5UJ-40MT/DSS: All versions
  • FX5UJ-60MT/ES: All versions
  • FX5UJ-60MT/DS: All versions
  • FX5UJ-60MT/ESS: All versions
  • FX5UJ-60MT/DSS: All versions
  • FX5UJ-24MR/ES: All versions
  • FX5UJ-24MR/DS: All versions
  • FX5UJ-40MR/ES: All versions
  • FX5UJ-40MR/DS: All versions
  • FX5UJ-60MR/ES: All versions
  • FX5UJ-60MR/DS: All versions
  • FX5UJ-24MR/ES-A: All versions
  • FX5UJ-24MT/ES-A: All versions
  • FX5UJ-40MR/ES-A: All versions
  • FX5UJ-40MT/ES-A: All versions
  • FX5UJ-60MR/ES-A: All versions
  • FX5UJ-60MT/ES-A: All versions
  • FX5S-30MT/ES: All versions
  • FX5S-30MT/DS: All versions
  • FX5S-30MT/ESS: All versions
  • FX5S-30MT/DSS: All versions
  • FX5S-40MT/ES: All versions
  • FX5S-40MT/DS: All versions
  • FX5S-40MT/ESS: All versions
  • FX5S-40MT/DSS: All versions
  • FX5S-60MT/ES: All versions
  • FX5S-60MT/DS: All versions
  • FX5S-60MT/ESS: All versions
  • FX5S-60MT/DSS: All versions
  • FX5S-80MT/ES: All versions
  • FX5S-80MT/DS: All versions
  • FX5S-80MT/ESS: All versions
  • FX5S-80MT/DSS: All versions
  • FX5S-30MR/ES: All versions
  • FX5S-30MR/DS: All versions
  • FX5S-40MR/ES: All versions
  • FX5S-40MR/DS: All versions
  • FX5S-60MR/ES: All versions
  • FX5S-60MR/DS: All versions
  • FX5S-80MR/ES: All versions
  • FX5S-80MR/DS: All versions
  • FX5S-30MR/ES-A: All versions
  • FX5S-30MT/ES-A: All versions
  • FX5S-40MR/ES-A: All versions
  • FX5S-40MT/ES-A: All versions
  • FX5S-60MR/ES-A: All versions
  • FX5S-60MT/ES-A: All versions
  • FX5S-80MR/ES-A: All versions
  • FX5S-80MT/ES-A: All versions
3.2.1 IMPROPER VALIDATION OF SPECIFIED QUANTITY IN INPUT CWE-1284
A denial-of-service (DoS) vulnerability exists in the TCP communication function on the MELSEC iQ-F Series CPU module. A remote attacker may be able to disconnect the connection by sending specially crafted TCP packets to cause a denial-of-service (DoS) condition on the products (CVE-2025-10259). There is no impact on connections other than the attacked one.
CVE-2025-10259 has been assigned to this vulnerability. A CVSS v3.1 base score of 5.3 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:L).
Qian Zou, Ke Xu, Xuewei Feng, Qi Li, Xueying Li, and Gang Jin from Zhongguancun Laboratory and Tsinghua University reported this vulnerability to Mitsubishi Electric.
Mitsubishi Electric recommends that users take the following mitigation measures to minimize the risk of exploiting this vulnerability:
  • Use a virtual private network (VPN) to encrypt the communication when Internet access is required.
  • Restrict physical access to the affected products and the LAN that is connected by them.
For more information, see Mitsubishi Electric Advisory 2025-014.
  • November 13, 2025: Initial Republication of Mitsubishi Electric Advisory 2025-014
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-317-01
