Saltar al contenido principal
IT BIBLEIniciar sesión
General Industrial Controls Lynx+ Gateway
  • CVSS v4 9.2
  • Vendor: General Industrial Controls
  • Equipment: Lynx+ Gateway
  • Vulnerabilities: Weak Password Requirements, Missing Authentication for Critical Function, Cleartext Transmission of Sensitive Information
Successful exploitation of these vulnerabilities could result in obtaining sensitive device information, unauthorized access, or create a denial-of-service condition.
The following versions of Lynx+ Gateway are affected:
  • Lynx+ Gateway: Version R08
  • Lynx+ Gateway: Version V03
  • Lynx+ Gateway: Version V05
  • Lynx+ Gateway: Version V18
3.2.1 WEAK PASSWORD REQUIREMENTS CWE-521
The affected product is vulnerable to a weak password requirement vulnerability, which may allow an attacker to execute a brute-force attack resulting in unauthorized access and login.
CVE-2025-55034 has been assigned to this vulnerability. A CVSS v3 base score of 8.2 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:L/A:N).
A CVSS v4 score has also been calculated for CVE-2025-55034. A base score of 8.8 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:L/VA:N/SC:N/SI:N/SA:N).
3.2.2 MISSING AUTHENTICATION FOR CRITICAL FUNCTION CWE-306
The affected product is missing critical authentication in the embedded web server which could allow an attacker to remotely reset the device.
CVE-2025-58083 has been assigned to this vulnerability. A CVSS v3 base score of 10.0 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:C/C:N/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-58083. A base score of 9.2 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:N/VI:H/VA:H/SC:N/SI:N/SA:H).
3.2.3 MISSING AUTHENTICATION FOR CRITICAL FUNCTION CWE-306
The affected product is missing critical authentication in the embedded web server which could allow an attacker to send GET requests to obtain sensitive device information.
CVE-2025-59780 has been assigned to this vulnerability. A CVSS v3 base score of 7.5 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:N/A:N).
A CVSS v4 score has also been calculated for CVE-2025-59780. A base score of 8.7 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:N/VA:N/SC:N/SI:N/SA:N).
3.2.4 CLEARTEXT TRANSMISSION OF SENSITIVE INFORMATION CWE-319
The affected product is vulnerable to a cleartext transmission vulnerability that could allow an attacker to observe network traffic to obtain sensitive information, including plaintext credentials.
CVE-2025-62765 has been assigned to this vulnerability. A CVSS v3 base score of 7.5 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:N/A:N).
A CVSS v4 score has also been calculated for CVE-2025-62765. A base score of 8.7 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:N/VA:N/SC:N/SI:N/SA:N).
  • COMPANY HEADQUARTERS LOCATION: India
Abhishek Pandey from Payatu Security Consulting Pvt. Ltd. reported these vulnerabilities to CISA.
General Industrial Controls (GIC) did not respond to CISA's attempts to coordinate. Users of General Industrial Controls Lynx+ Gateway are encouraged to reach out to GIC for more information.
  • November 13, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-317-08
