Siemens Altair Grid Engine
  • CVSS v3 7.8
  • Equipment: Altair Grid Engine
  • Vulnerabilities: Generation of Error Message Containing Sensitive Information, Uncontrolled Search Path Element
Successful exploitation of these vulnerabilities could allow an attacker to escalate privileges and execute arbitrary code with superuser permissions.
The following versions of Altair Grid Engine are affected:
  • Altair Grid Engine: All versions prior to V2026.0.0
3.2.1 GENERATION OF ERROR MESSAGE CONTAINING SENSITIVE INFORMATION CWE-209
Affected products do not properly handle error messages and disclose sensitive password hash information when processing user authentication requests. This could allow a local attacker to extract password hashes for privileged accounts, which can then be subjected to offline brute-force attacks.
CVE-2025-40760 has been assigned to this vulnerability. A CVSS v3.1 base score of 5.5 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:L/UI:N/S:U/C:H/I:N/A:N).
3.2.2 UNCONTROLLED SEARCH PATH ELEMENT CWE-427
Affected products do not properly validate environment variables when loading shared libraries, allowing path hijacking through malicious library substitution. This could allow a local attacker to execute arbitrary code with superuser privileges by manipulating the environment variable and placing a malicious library in the controlled path.
CVE-2025-40763 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.8 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:L/UI:N/S:U/C:H/I:H/A:H).
Daniele Montanaro reported these vulnerabilities to Siemens. Siemens ProductCERT reported these vulnerabilities to CISA.
  • Update to V2026.0.0 or later version.
  • CVE-2025-40760: For clusters not using the UGERest API/daemon remove the setuid-root bit from the binaries for all architectures: chmod u-s $SGE_ROOT/utilbin//authuser.
  • CVE-2025-40763: For non Windows clusters remove the setuid-root bit from the "sgepasswd" binary for all installed architectures: chmod u-s $SGE_ROOT/bin//sgepasswd.
For more information see the associated Siemens security advisory SSA-514895 in HTML and CSAF.
  • November 13, 2025: Initial Republication of Siemens SSA-514895
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-317-16
