Siemens SICAM P850 family and SICAM P855 family
  • CVSS v3 5.5
  • Equipment: SICAM P850 family and SICAM P855 family
  • Vulnerabilities: Cross-Site Request Forgery (CSRF), Incorrect Permission Assignment for Critical Resource
Successful exploitation of these vulnerabilities could allow an attacker to perform arbitrary actions on the device on behalf of a legitimate user, or impersonate that user.
  • SICAM P850 (7KG8500-0AA00-0AA0): Versions prior to 3.11
  • SICAM P850 (7KG8501-0AA02-2AA0): Versions prior to 3.11
  • SICAM P850 (7KG8501-0AA11-0AA0): Versions prior to 3.11
  • SICAM P850 (7KG8501-0AA11-2AA0): Versions prior to 3.11
  • SICAM P850 (7KG8501-0AA12-0AA0): Versions prior to 3.11
  • SICAM P850 (7KG8501-0AA12-2AA0): Versions prior to 3.11
  • SICAM P850 (7KG8501-0AA31-0AA0): Versions prior to 3.11
  • SICAM P850 (7KG8501-0AA31-2AA0): Versions prior to 3.11
  • SICAM P850 (7KG8501-0AA32-0AA0): Versions prior to 3.11
  • SICAM P850 (7KG8501-0AA32-2AA0): Versions prior to 3.11
  • SICAM P855 (7KG8550-0AA00-0AA0): Versions prior to 3.11
  • SICAM P850 (7KG8500-0AA00-2AA0): Versions prior to 3.11
  • SICAM P855 (7KG8550-0AA00-2AA0): Versions prior to 3.11
  • SICAM P855 (7KG8550-0AA10-0AA0): Versions prior to 3.11
  • SICAM P855 (7KG8550-0AA10-2AA0): Versions prior to 3.11
  • SICAM P855 (7KG8550-0AA30-0AA0): Versions prior to 3.11
  • SICAM P855 (7KG8550-0AA30-2AA0): Versions prior to 3.11
  • SICAM P855 (7KG8551-0AA01-0AA0): Versions prior to 3.11
  • SICAM P855 (7KG8551-0AA01-2AA0): Versions prior to 3.11
  • SICAM P855 (7KG8551-0AA02-0AA0): Versions prior to 3.11
  • SICAM P855 (7KG8551-0AA02-2AA0): Versions prior to 3.11
  • SICAM P855 (7KG8551-0AA11-0AA0): Versions prior to 3.11
  • SICAM P850 (7KG8500-0AA10-0AA0): Versions prior to 3.11
  • SICAM P855 (7KG8551-0AA11-2AA0): Versions prior to 3.11
  • SICAM P855 (7KG8551-0AA12-0AA0): Versions prior to 3.11
  • SICAM P855 (7KG8551-0AA12-2AA0): Versions prior to 3.11
  • SICAM P855 (7KG8551-0AA31-0AA0): Versions prior to 3.11
  • SICAM P855 (7KG8551-0AA31-2AA0): Versions prior to 3.11
  • SICAM P855 (7KG8551-0AA32-0AA0): Versions prior to 3.11
  • SICAM P855 (7KG8551-0AA32-2AA0): Versions prior to 3.11
  • SICAM P850 (7KG8500-0AA10-2AA0): Versions prior to 3.11
  • SICAM P850 (7KG8500-0AA30-0AA0): Versions prior to 3.11
  • SICAM P850 (7KG8500-0AA30-2AA0): Versions prior to 3.11
  • SICAM P850 (7KG8501-0AA01-0AA0): Versions prior to 3.11
  • SICAM P850 (7KG8501-0AA01-2AA0): Versions prior to 3.11
  • SICAM P850 (7KG8501-0AA02-0AA0): Versions prior to 3.11
3.2.1 CROSS-SITE REQUEST FORGERY (CSRF) CWE-352
The web interface of the affected devices are vulnerable to Cross-Site Request Forgery attacks. By tricking an authenticated victim user to click a malicious link, an attacker could perform arbitrary actions on the device on behalf of the victim user.
CVE-2023-30901 has been assigned to this vulnerability. A CVSS v3.1 base score of 4.3 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:R/S:U/C:N/I:L/A:N).
3.2.2 INCORRECT PERMISSION ASSIGNMENT FOR CRITICAL RESOURCE CWE-732
Affected devices are missing cookie protection flags when using the default settings. An attacker who gains access to a session token can use it to impersonate a legitimate application user.
CVE-2023-31238 has been assigned to this vulnerability. A CVSS v3.1 base score of 5.5 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:H/PR:L/UI:R/S:C/C:L/I:L/A:L).
Siemens ProductCERT reported these vulnerabilities to CISA.
  • Update to V3.11 or later version
  • (CVE-2023-30901) All affected products: Do not access links from untrusted sources while logged in at affected devices
  • (CVE-2023-31238) All affected products: Restrict access to port 443/tcp to trusted IP addresses only
For more information see the associated Siemens security advisory SSA-201498 in HTML and CSAF.
  • November 13, 2025: Initial Republication of Siemens ProductCERT SSA-201498
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-317-11
