ASKI Energy ALS-Mini-S8 and ALS-Mini-S4
  • CVSS v4 9.9
  • Vendor: ASKI Energy
  • Equipment: ALS-Mini-S8, ALS-mini-s4 IP
  • Vulnerability: Missing Authentication for Critical Function
Successful exploitation of this vulnerability could allow an attacker to gain full control over the device.
The following ASKI Energy products are affected:
  • ALS-mini-s4 IP (serial number from 2000 to 5166): All versions
  • ALS-mini-s8 IP (serial number from 2000 to 5166): All versions
3.2.1 Missing Authentication for Critical Function CWE-306
A critical severity missing authentication vulnerability exists in the embedded web server of the ALS-mini-S4/S8 IP controllers. There is a lack of authentication functionality. Specifically, an attacker can read and modify product configuration parameters without being authenticated.
CVE-2025-9574 has been assigned to this vulnerability. A CVSS v3.1 base score of 10.0 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:C/C:H/I:H/A:N).
A CVSS v4 score has also been calculated for CVE-2025-9574. A base score of 9.9 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:N/SC:N/SI:N/SA:H).
  • CRITICAL INFRASTRUCTURE SECTORS: Energy, Critical Manufacturing
  • COUNTRIES/AREAS DEPLOYED: Europe
  • COMPANY HEADQUARTERS LOCATION: Austria
Souvik Kandar of MicroSec (microsec.io) reported this vulnerability to CISA.
ABB, the parent company of ASKI, reports that the affected products reached their end of life in 2022. As these products are no longer supported, there are no plans for a fix. ABB recommends the following mitigations:
  • Ensure the product is not exposed to the public internet.
  • Within the control system, put the product behind firewall, to strictly control network traffic only from limited whitelisted IPs or alternatively, route the traffic through a secure proxy that enforces authentication and logging.
  • Monitor product access using firewall, IDS, or IPS, and configure alerts for any access attempts from non-whitelisted IPs.
  • Ensure surrounding systems are fully updated to reduce attack vectors.
Additionally ABB recommends the following work around:
  • Physically disconnect the ethernet port if embedded web server is not being used.
The embedded web server and all its functionalities, incl. load monitoring, alarms, remote configuration, etc. will not be accessible. However, the product will continue functioning as normal based on configured control parameters.
For more information, please reference ABB's security advisory 4TZ00000006007.
  • October 23, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-296-02
