Delta Electronics ASDA-Soft
  • CVSS v4 8.4
  • Vendor: Delta Electronics
  • Equipment: ASDA-Soft
Successful exploitation of these vulnerabilities could allow an attacker to write data outside of the allocated memory buffer.
Delta Electronics reports the following versions of ASDA-Soft servo software are affected:
  • ASDA-Soft: Version 7.0.2.0 and prior
3.2.1 Stack-based Buffer Overflow CWE-121
Delta Electronics ASDA-Soft can write data outside of the intended memory buffer when a valid user opens a maliciously crafted project file.
CVE-2025-62579 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:L/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-62579. A base score of 8.4 has been calculated; the CVSS vector string is (CVSS:4.0/AV:L/AC:L/AT:N/PR:N/UI:A/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
3.2.2 Stack-based Buffer Overflow CWE-121
CVE-2025-62580 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:L/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-62580. A base score of 8.4 has been calculated; the CVSS vector string is (CVSS:4.0/AV:L/AC:L/AT:N/PR:N/UI:A/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
Guillaume Orlando working with Trend Micro Zero Day Initiative reported these vulnerabilities to CISA.
Delta Electronics has released an updated version of ASDA-Soft and recommends users install v7.1.1.0 or newer.
For more information, see Delta Electronics advisory Delta-PCSA-2025-00019.
Delta Electronics offers the following general recommendations:
  • Do not click on untrusted Internet links or open unsolicited attachments in emails.
  • Place systems and devices behind a firewall and isolate them from the business network.
Contact Delta Electronics via their portal page for any product-related support concerns, information, or materials you may require.
  • October 23, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-296-04
