Rockwell Automation 1783-NATR
  • CVSS v4 9.9
  • Equipment: 1783-NATR
  • Vulnerabilities: Missing Authentication for Critical Function, Improper Neutralization of Input During Web Page Generation ('Cross-site Scripting'), Cross-Site Request Forgery (CSRF)
Successful exploitation of these vulnerabilities could result in a denial-of-service, data modification, or in an attacker obtaining sensitive information.
The following versions of 1783-NATR are affected:
  • 1783-NATR: Version 1.006 and prior
Multiple Broken Authentication security issues exist in the affected product. The security issues are due to missing authentication checks on critical functions. These could result in potential denial-of-service, admin account takeover, or NAT rule modifications. Devices would no longer be able to communicate through NATR as a result of denial-of-service or NAT rule modifications. NAT rule modification could also result in device communication to incorrect endpoints. Admin account takeover could allow modification of configuration and require physical access to restore.
CVE-2025-7328 has been assigned to this vulnerability. A CVSS v3 base score of 10.0 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:C/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-7328. A base score of 9.9 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:H).
3.2.2 IMPROPER NEUTRALIZATION OF INPUT DURING WEB PAGE GENERATION ('CROSS-SITE SCRIPTING') CWE-79
A Stored Cross-Site Scripting security issue exists in the affected product that could potentially allow a malicious user to view and modify sensitive data or make the webpage unavailable. The vulnerability stems from missing special character filtering and encoding. Successful exploitation requires an attacker to be able to update configuration fields behind admin login.
CVE-2025-7329 has been assigned to this vulnerability. A CVSS v3 base score of 8.4 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:H/UI:R/S:C/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-7329. A base score of 8.5 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:H/UI:P/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
3.2.3 CROSS-SITE REQUEST FORGERY (CSRF) CWE-352
A cross-site request forgery security issue exists in the product and version listed. The vulnerability stems from missing CSRF checks on the impacted form. This allows for unintended configuration modification if an attacker can convince a logged in admin to visit a crafted link.
CVE-2025-7330 has been assigned to this vulnerability. A CVSS v3 base score of 8.0 has been calculated; the CVSS vector string is (AV:N/AC:H/PR:N/UI:R/S:C/C:N/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-7330. A base score of 7.0 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:A/VC:N/VI:H/VA:H/SC:N/SI:N/SA:N).
Rockwell Automation recommends users upgrade their devices to 1.007 or later.
Users of the affected software unable to upgrade to one of the corrected
versions should follow Rockwell Automation's security best practices.
  • October 21, 2025: Initial Republication of Rockwell Automation advisory SD1756
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-294-01
