  • Equipment: SINEC NMS
  • Vulnerability: Improper Neutralization of Special Elements used in an SQL Command ('SQL Injection')
Successful exploitation of this vulnerability could allow an authenticated low privileged attacker to insert malicious data and achieve privilege escalation.
  • SINEC NMS: Versions prior to V4.0 SP1
3.2.1 IMPROPER NEUTRALIZATION OF SPECIAL ELEMENTS USED IN AN SQL COMMAND ('SQL INJECTION') CWE-89
Affected applications are vulnerable to SQL injection through getTotalAndFilterCounts endpoint. An authenticated low privileged attacker could exploit to insert data and achieve privilege escalation. (ZDI-CAN-26570)
CVE-2025-40755 has been assigned to this vulnerability. A CVSS v3.1 base score of 8.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-40755. A base score of 8.7 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:L/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
For more information see the associated Siemens security advisory SSA-318832 in HTML and CSAF.
  • October 16, 2025: Initial Republication of Siemens ProductCERT SSA-318832
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-289-08
