Aller au contenu principal
IT BIBLESe connecter
Rockwell Automation ArmorStart AOP
  • Equipment: ArmorStart AOP
  • Vulnerability: Uncaught Exception
Successful exploitation of this vulnerability could allow an attacker to cause a denial-of-service condition on the affected product.
The following Rockwell Automation products are affected:
  • ArmorStart AOP: Version V2.05.07 and prior
3.2.1 Uncaught Exception CWE-248
A security issue exists within the Studio 5000 Logix Designer add-on profile (AOP) for the ArmorStart Classic distributed motor controller, resulting in a denial-of-service. This vulnerability is possible due to the input of invalid values into Component Object Model (COM) methods.
CVE-2025-9437 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.5 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:H).
A CVSS v4 score has also been calculated for CVE-2025-9437. A base score of 8.7 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:N/VI:N/VA:H/SC:N/SI:N/SA:N).
Rockwell Automation reports there is no fix available and recommends users of the affected product follow security best practices.
For more information, visit Rockwell Automation Security Advisories.
  • October 16, 2025: Initial Republication of Rockwell Automation Security Advisory SD1751
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-289-04
Se connecter pour répondre.
