Rockwell Automation FactoryTalk Linx
  • CVSS v4 8.5
  • Equipment: FactoryTalk Linx
  • Vulnerabilities: Privilege Chaining
Successful exploitation of these vulnerabilities may allow full access to all files, processes, and system resources.
Rockwell Automation reports that the following versions of the FactoryTalk Linx control system data communications platform are affected:
  • FactoryTalk Linx: Versions 6.40 and prior
3.2.1 PRIVILEGE CHAINING CWE-268
A security issue exists within the x86 Microsoft Installer File (MSI), which is installed with FTLinx. Authenticated attackers with valid Windows user credentials can initiate a repair and hijack the resulting console window. This allows the launching of a command prompt running with SYSTEM-level privileges, which provides full access to all files, processes, and system resources.
CVE-2025-9067 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:L/AC:L/PR:L/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-9067. A base score of 8.5 has been calculated; the CVSS vector string is (CVSS:4.0/AV:L/AC:L/AT:N/PR:L/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
3.2.2 PRIVILEGE CHAINING CWE-268
A security issue exists within the Rockwell Automation Driver Package x64 Microsoft Installer File (MSI) repair functionality, which is installed with FTLinx. Authenticated attackers with valid Windows user credentials can initiate a repair and hijack the resulting vbpinstall.exe console window. This allows the launching of a command prompt with SYSTEM-level privileges, granting full access to all files, processes, and system resources.
CVE-2025-9068 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:L/AC:L/PR:L/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-9068. A base score of 8.5 has been calculated; the CVSS vector string is (CVSS:4.0/AV:L/AC:L/AT:N/PR:L/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
Rockwell Automation recommends users of the affected software consider installing the Microsoft patch to address the MSI issue. If possible, users should also upgrade to version 6.50 or later. Users of the affected software unable to upgrade to one of the corrected versions should follow Rockwell Automation's security best practices.
For more information, see Rockwell Automation's security advisory SD1754.
CISA recommends users take the following measures to protect themselves from social engineering attacks:
  • October 16, 2025: Initial Republication of Rockwell Automation's security advisory SD1754.
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-289-02
