Zum Hauptinhalt springen
IT BIBLEAnmelden
National Instruments Circuit Design Suite
  • CVSS v4 8.4
  • Vendor: National Instruments
  • Equipment: Circuit Design Suite
  • Vulnerabilities: Type Confusion, Out-of-bounds Read
Successful exploitation of these vulnerabilities could allow an attacker to cause memory corruption, potentially leading to information disclosure and execution of arbitrary code.
The following National Instruments products are affected:
  • Circuit Design Suite: Versions v14.3.1 and prior
3.2.1 ACCESS OF RESOURCE USING INCOMPATIBLE TYPE ('TYPE CONFUSION') CWE-843
The affected product is vulnerable to a memory corruption of a function table, which could allow an attacker to disclose information or execute arbitrary code.
CVE-2025-6033 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.8 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-6033. A base score of 8.4 has been calculated; the CVSS vector string is (AV:L/AC:L/AT:N/PR:N/UI:A/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
3.2.2 OUT-OF-BOUNDS READ CWE-125
The affected product is vulnerable to an out-of-bounds read, which may allow an attacker to execute arbitrary code.
CVE-2025-6034 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.8 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-6034. A base score of 8.4 has been calculated; the CVSS vector string is (AV:L/AC:L/AT:N/PR:N/UI:A/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Communications, Defense Industrial Base, Government Services and Facilities
Michael Heinzl reported these vulnerabilities to CISA.
National Instruments recommends users update to version 14.3.2 or later from NI Package Manager or Software Downloads.
For more information, refer to the National Instruments security pages for each vulnerability:
See the National Instruments security update page for additional information.
  • September 30, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-273-06
Anmelden um zu antworten.
