Schneider Electric SESU
  • CVSS v3 7.3
  • Vendor: Schneider Electric
  • Equipment: SESU
  • Vulnerability: Improper Link Resolution Before File Access ('Link Following')
Successful exploitation of this vulnerability could allow an authenticated attacker to write arbitrary data to protected locations, potentially leading to escalation of privilege, arbitrary file corruption, exposure of application and system information or persistent denial of service when a low-privileged attacker tampers with the installation folder.
  • Schneider Electric SESU: <3.0.12
  • Schneider Electric SESU installed on Schneider Electric BESS ANSI: SESU versions prior to 3.0.12
  • Schneider Electric SESU installed on Schneider Electric Easergy MiCOM P30: SESU versions prior to 3.0.12
  • Schneider Electric SESU installed on Schneider Electric Easergy MiCOM P40: SESU versions prior to 3.0.12
  • Schneider Electric SESU installed on Schneider Electric Easergy Studio: SESU versions prior to 3.0.12
  • Schneider Electric SESU installed on Schneider Electric EcoStruxure Automation Expert: SESU versions prior to 3.0.12
  • Schneider Electric SESU installed on Schneider Electric Harmony XB5S Soft: SESU versions prior to 3.0.12
  • Schneider Electric SESU installed on Schneider Electric eXLhoist Configuration Software: SESU versions prior to 3.0.12
  • Schneider Electric SESU installed on Schneider Electric EcoStruxure Automation Device Maintenance: SESU versions prior to 3.0.12
  • Schneider Electric SESU installed on Schneider Electric EcoStruxure Machine Expert: SESU versions prior to 3.0.12
  • Schneider Electric SESU installed on Schneider Electric EcoStruxure Machine Expert Basic: SESU versions prior to 3.0.12
  • Schneider Electric SESU installed on Schneider Electric EcoStruxure Automation Expert Motion: SESU versions prior to 3.0.12
  • Schneider Electric SESU installed on Schneider Electric EcoStruxure Operator Terminal Expert: SESU versions prior to 3.0.12
  • Schneider Electric SESU installed on Schneider Electric EcoStruxure Control Expert: SESU versions prior to 3.0.12
  • Schneider Electric SESU installed on Schneider Electric EcoStruxure Process Expert: SESU versions prior to 3.0.12
  • Schneider Electric SESU installed on Schneider Electric EcoStruxure Process Expert for AVEVA System Platform: SESU versions prior to 3.0.12
  • Schneider Electric SESU installed on Schneider Electric EcoStruxure Architecture Builder: SESU versions prior to 3.0.12
  • Schneider Electric SESU installed on Schneider Electric EcoStruxure Machine Expert HVAC: SESU versions prior to 3.0.12
  • Schneider Electric SESU installed on Schneider Electric EcoStruxure Power Operations (EPO): SESU versions prior to 3.0.12
  • Schneider Electric SESU installed on Schneider Electric EcoStruxure Power Commission Desktop (EPC): SESU versions prior to 3.0.12
  • Schneider Electric SESU installed on Schneider Electric EcoStruxure Microgrid Operations Medium: SESU versions prior to 3.0.12
  • Schneider Electric SESU installed on Schneider Electric EcoStruxure Microgrid Flex: SESU versions prior to 3.0.12
  • Schneider Electric SESU installed on Schneider Electric PowerLogic P5: SESU versions prior to 3.0.12
  • Schneider Electric SESU installed on Schneider Electric PowerLogic P7: SESU versions prior to 3.0.12
  • Schneider Electric SESU installed on Schneider Electric ZelioSoft 2: SESU versions prior to 3.0.12
  • Schneider Electric SESU installed on Schneider Electric SoMove: SESU versions prior to 3.0.12
3.2.1 IMPROPER LINK RESOLUTION BEFORE FILE ACCESS ('LINK FOLLOWING') CWE-59
A link following vulnerability exists that could cause arbitrary data to be written to protected locations, potentially leading to escalation of privilege, arbitrary file corruption, exposure of application and system information or persistent denial of service when a low-privileged attacker tampers with the installation folder.
CVE-2025-5296 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.3 has been calculated; the CVSS vector string is (CVSS:3.1/AV:L/AC:L/PR:L/UI:N/S:U/C:L/I:H/A:H).
  • CRITICAL INFRASTRUCTURE SECTORS: Chemical, Commercial Facilities, Critical Manufacturing, Energy, Healthcare and Public Health, Information Technology, Transportation Systems, Water and Wastewater Systems
Sheikh Rishad reported this vulnerability to Schneider Electric.
Schneider Electric reported this vulnerability to CISA.
  • Version 3.0.12 of SESU includes a fix for this vulnerability and is available for download here. Follow the installation instructions. If a predecessor version of SESU is already installed, then the update to V3.0.12 will be done automatically as a critical update in the background depending on the "automatic" update configuration.
  • If users choose not to apply the remediation detailed above, they should immediately apply the following mitigations to reduce the risk of exploit: SESU Installation Directory (chosen by the user at installation time) should not be accessible from the network and only by trusted persons.
For more information see the associated Schneider Electric CPCERT security advisory SEVD-2025-224-03 Schneider Electric Software Update - SEVD-2025-224-03 PDF Version, Schneider Electric Software Update - SEVD-2025-224-03 CSAF Version.
  • September 23, 2025: Initial Republication of Schneider Electric CPCERT SEVD-2025-224-03
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-266-03
