Aller au contenu principal
IT BIBLESe connecter
Mitsubishi Electric MELSEC-Q Series CPU Module
  • CVSS v3.1 6.8
  • Vendor: Mitsubishi Electric
  • Equipment: MELSEC-Q Series CPU module
  • Vulnerability: Improper Handling of Length Parameter Inconsistency
Successful exploitation of this vulnerability could allow an attacker to cause a denial of service (DoS).
The following versions of Mitsubishi Electric MELSEC-Q Series CPU modules are affected:
  • MELSEC-Q Series Q03UDVCPU: The first 5 digits of serial No. '24082' to '27081'
  • MELSEC-Q Series Q04UDVCPU: The first 5 digits of serial No. '24082' to '27081'
  • MELSEC-Q Series Q06UDVCPU: The first 5 digits of serial No. '24082' to '27081'
  • MELSEC-Q Series Q13UDVCPU: The first 5 digits of serial No. '24082' to '27081'
  • MELSEC-Q Series Q26UDVCPU: The first 5 digits of serial No. '24082' to '27081'
  • MELSEC-Q Series Q04UDPVCPU: The first 5 digits of serial No. '24082' to '27081'
  • MELSEC-Q Series Q06UDPVCPU: The first 5 digits of serial No. '24082' to '27081'
  • MELSEC-Q Series Q13UDPVCPU: The first 5 digits of serial No. '24082' to '27081'
  • MELSEC-Q Series Q26UDPVCPU: The first 5 digits of serial No. '24082' to '27081'
3.2.1 Improper Handling of Length Parameter Inconsistency CWE-130
A Denial-of-Service (DoS) vulnerability exists in the MELSEC-Q series CPU module when the user authentication function is enabled, due to improper handling of length parameter inconsistency.
CVE-2025-8531 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.8 has been calculated; the CVSS vector string is (AV:N/AC:H/PR:N/UI:N/S:C/C:N/I:N/A:H).
Mitsubishi Electric reported this vulnerability to CISA.
Mitsubishi Electric has released the fixed version as shown below, but updating the product to the fixed version is currently unavailable. Consider migrating to the successor model, MELSEC iQ-R Series.
  • MELSEC-QSeries Q03UDVCPU: The first 5 digits of serial No. '27082' or later.
  • MELSEC-QSeries Q04UDVCPU: The first 5 digits of serial No. '27082' or later.
  • MELSEC-QSeries Q06UDVCPU: The first 5 digits of serial No. '27082' or later.
  • MELSEC-QSeries Q13UDVCPU: The first 5 digits of serial No. '27082' or later.
  • MELSEC-QSeries Q26UDVCPU: The first 5 digits of serial No. '27082' or later.
  • MELSEC-QSeries Q04UDPVCPU: The first 5 digits of serial No. '27082' or later.
  • MELSEC-QSeries Q06UDPVCPU: The first 5 digits of serial No. '27082' or later.
  • MELSEC-QSeries Q13UDPVCPU: The first 5 digits of serial No. '27082' or later.
  • MELSEC-QSeries Q26UDPVCPU: The first 5 digits of serial No. '27082' or later.
Mitsubishi Electric recommends users employ the following mitigation measures to minimize the risk of vulnerability exploit.
  • Use a firewall or virtual private network (VPN), etc. to prevent unauthorized access when Internet access is required.
  • Use within a LAN and block access from untrusted networks and hosts through firewalls.
  • Restrict physical access to the affected products, as well as to computers and network devices that can be connected to those products.
See Mitsubishi Electric's security bulletin for more information.
  • September 23, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-266-02
Se connecter pour répondre.
