Zum Hauptinhalt springen
IT BIBLEAnmelden
Hitachi Energy Asset Suite
  • Vendor: Hitachi Energy
  • Equipment: Asset Suite
  • Vulnerabilities: Server-Side Request Forgery (SSRF), Deserialization of Untrusted Data, Cleartext Storage of Sensitive Information, Uncontrolled Resource Consumption, URL Redirection to Untrusted Site ('Open Redirect'), Improper Authentication
Successful exploitation of this vulnerability could allow attackers to trigger resource consumption or information disclosure through SSRF in Apache XML Graphics Batik, mount a Denial-Of-Service attack via poisoned data in logback, discover cleartext passwords in H2 Database Engine, fill up the file system in Apache CXF, perform open redirect or SSRF attacks through UriComponentsBuilder, and execute arbitrary code in Apache ActiveMQ.
Hitachi Energy reports that the following products are affected:
  • Asset Suite: Versions 9.6.4.5 and prior
3.2.1 SERVER-SIDE REQUEST FORGERY (SSRF) CWE-918
Server-Side Request Forgery (SSRF) vulnerability in Apache Software Foundation Apache XML Graphics Batik. This issue affects Apache XML Graphics Batik: 1.16. On version 1.16, a malicious SVG could trigger loading external resources by default, causing resource consumption or in some cases even information disclosure.
CVE-2022-44729 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.1 has been calculated; the CVSS vector string is (CVSS:3.1/AV:L/AC:L/PR:N/UI:R/S:U/C:H/I:N/A:H).
A CVSS v4 score has also been calculated for CVE-2022-44729. A base score of 6.9 has been calculated; the CVSS vector string is (CVSS:4.0/AV:L/AC:L/AT:N/PR:N/UI:P/VC:H/VI:N/VA:H/SC:N/SI:N/SA:N).
3.2.2 DESERIALIZATION OF UNTRUSTED DATA CWE-502
A serialization vulnerability in logback receiver component part of logback version 1.4.11 allows an attacker to mount a Denial-of-Service attack by sending poisoned data. This vulnerability affects logback versions prior to 1.2.13, 1.3.12 and 1.4.12.
CVE-2023-6378 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.5 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:H).
A CVSS v4 score has also been calculated for CVE-2023-6378. A base score of 8.7 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:L/UI:N/VC:N/VI:H/VA:N/SC:N/SI:N/SA:N).
3.2.3 CLEARTEXT STORAGE OF SENSITIVE INFORMATION CWE-312
The web-based admin console in H2 Database Engine before 2.2.220 can be started via the CLI with the argument -webAdminPassword, which allows the user to specify the password in cleartext for the web admin console. Consequently, a local user (or an attacker that has obtained local access through some means) would be able to discover the password by listing processes and their arguments. The issue was fixed in 2.2.220 by the vendor H2.
CVE-2022-45868 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:L/AC:L/PR:L/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2022-45868. A base score of 8.5 has been calculated; the CVSS vector string is (CVSS:4.0/AV:L/AC:L/AT:N/PR:L/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
3.2.4 UNCONTROLLED RESOURCE CONSUMPTION CWE-400
A potential denial of service vulnerability is present in versions of Apache CXF before 3.5.10, 3.6.5 and 4.0.6. In some edge cases, the CachedOutputStream instances may not be closed and, if backed by temporary files, may fill up the file system (it applies to servers and clients).
CVE-2025-23184 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.5 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:H).
A CVSS v4 score has also been calculated for CVE-2025-23184. A base score of 8.7 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:N/UI:N/VC:N/VI:N/VA:H/SC:N/SI:N/SA:N).
3.2.5 URL REDIRECTION TO UNTRUSTED SITE ('OPEN REDIRECT') CWE-601
Applications that use UriComponentsBuilder to parse an externally provided URL (e.g. through a query parameter) AND perform validation checks on the host of the parsed URL may be vulnerable to a open redirect attack or to a SSRF attack if the URL is used after passing validation checks.
CVE-2024-22262 has been assigned to this vulnerability. A CVSS v3.1 base score of 8.1 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:N).
A CVSS v4 score has also been calculated for CVE-2024-22262. A base score of 8.6 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:N/UI:P/VC:H/VI:H/VA:N/SC:N/SI:N/SA:N).
3.2.6 IMPROPER AUTHENTICATION CWE-287
In Apache ActiveMQ, once a user is authenticated on Jolokia, the user can potentially trigger arbitrary code execution. In details, in ActiveMQ configurations, jetty allows org.jolokia.http.AgentServlet to handle request to /api/jolokia org.jolokia.http.HttpRequestHandler#handlePostRequest is able to create JmxRequest through JSONObject. And calls to org.jolokia.http.HttpRequestHandler#executeRequest. Into deeper calling stacks, org.jolokia.handler.ExecHandler#doHandleRequest can be invoked through reflection. This could lead to RCE through via various mbeans.
CVE-2022-41678 has been assigned to this vulnerability. A CVSS v3.1 base score of 8.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2022-41678. A base score of 8.7 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:L/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
  • COMPANY HEADQUARTERS LOCATION: Switzerland
Hitachi Energy PSIRT reported these vulnerabilities to CISA.
Hitachi Energy has identified the following specific workarounds and mitigations users can apply to reduce risk:
  • Asset Suite versions 9.6.4.5 and prior: Apply general mitigation factors
  • (CVE-2022-44729, CVE-2023-6378, CVE-2022-45868, CVE-2025-23184, CVE-2024-22262) Asset Suite versions 9.6.4.5 and prior: Upgrade to version 9.7
  • (CVE-2022-41678) Asset Suite versions 9.6.4.5 and prior: Upgrade to version 9.8 when available
For more information see the associated Hitachi Energy PSIRT security advisory 8DBD000221 Multiple Open-Source Software Vulnerabilities in Hitachi Energy Asset Suite Product.
  • September 18, 2025: Initial Republication of Hitachi Energy PSIRT 8DBD000221
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-261-04
Anmelden um zu antworten.
