Malicious Listener for Ivanti Endpoint Mobile Management Systems
### Malware Analysis at a Glance
Executive Summary The Cybersecurity and Infrastructure Security Agency (CISA) obtained two sets of malware from an organization compromised by cyber threat actors exploiting CVE-2025-4427 and CVE-2025-4428 in Ivanti Endpoint Manager Mobile (Ivanti EPMM). Each set contains loaders for malicious listeners that enable cyber threat actors to run arbitrary code on the compromised server.
Affected Products Ivanti EPMM, versions 11.12.0.4 and prior, 12.3.0.1 and prior, 12.4.0.1 and prior, and 12.5.0.0 and prior. (Ivanti provided a patch and disclosed the vulnerabilities on May 13, 2025.)
Key Actions - Detect activity by using the indicators of compromise (IOCs) and detection signatures to identify malware samples. - Prevent compromise by upgrading Ivanti EPMM versions to the latest version as soon as possible. - Prevent compromise by treating mobile device management (MDM) systems as high-value assets (HVAs) with additional restrictions and monitoring.
Indicators of Compromise For a downloadable copy of IOCs associated with this malware, see: MAR-251126.r1.v1.CLEAR.
Detection This malware analysis report includes YARA and SIGMA rules. For a downloadable copy of the SIGMA rule associated with this malware, see: AR25-260A/B SIGMA YAML.
Intended Audience Organizations: All organizations with on-premises Ivanti EPMM systems. Roles: Digital forensics analysts, incident responders, vulnerability analysts, system administrators.
Introduction
The Cybersecurity and Infrastructure Security Agency (CISA) obtained two sets of malware, five files in total, from an organization where cyber threat actors exploited CVE-2025-4427 [CWE-288: Authentication Bypass Using an Alternate Path or Channel] and CVE-2025-4428 [CWE-‘Code Injection’] in Ivanti Endpoint Manager Mobile (Ivanti EPMM) deployments for initial access.
Note: Ivanti provided a patch and disclosed the vulnerabilities on May 13, 2025. CISA added both vulnerabilities to its Known Exploited Vulnerabilities Catalog on May 19, 2025.
Around May 15, 2025, following publication of a proof of concept, the cyber threat actors gained access to the server running EPMM by chaining these vulnerabilities. The cyber threat actors targeted the /mifs/rs/api/v2/ endpoint with HTTP GET requests and used the ?format= parameter to send malicious remote commands. The commands enabled the threat actors to collect system information, download malicious files, list the root directory, map the network, execute scripts to create a heapdump, and dump Lightweight Directory Access Protocol (LDAP) credentials.
CISA analyzed two sets of malicious files the cyber threat actors wrote to the /tmp directory. Each set of malware enabled persistence by allowing the cyber threat actors to inject and run arbitrary code on the compromised server.
CISA encourages organizations to use the indicators of compromise (IOCs) and detection signatures in this Malware Analysis Report to identify malware samples. If identified, follow the guidance in the Incident Response section of this Malware Analysis Report. Additionally, organizations should ensure they are running the latest version of Ivanti EPMM as soon as possible.
Download the PDF version of this report:
Malware Analysis Report Malicious Listener for Ivanti Endpoint Mobile Management Systems (PDF, 809.61 KB )
MAR-251126.r1.v1.CLEAR (JSON, 45.68 KB )
CMA_SIGMA_MAR_251126_Ivanti_EPMM_CVE_2025_4427_TLP_CLEARCMA_SIGMA_MAR_251126_Ivanti_EPMM_CVE_2025_4427_TLP_CLEAR (YAML, 3.89 KB )
Malware Summary
CISA analyzed two sets of malware:
  • Set 1 consists of the following malicious files: web-install.jar, ReflectUtil.class, and SecurityHandlerWanListener.class.
  • Set 2 consists of the following malicious files: web-install.jar and WebAndroidAppInstaller.class.
Note: To distinguish the set 1 malware, named web-install.jar, from the set 2 malware with the same name, hereafter this Malware Analysis Report will refer to:
  • Set 1’s web-install.jar as Loader 1.
  • Set 2’s web-install.jar as Loader 2.
Each set contains a loader and malicious listener that enables cyber threat actors to inject and run arbitrary code on the compromised server.
Set 1 works together in the following ways:
  1. Loader 1 contains and loads ReflectUtil.class.
    1. ReflectUtil.class injects and manages SecurityHandlerWanListener in Apache Tomcat.
      1. SecurityHandlerWanListener.class intercepts specific HTTP requests and processes them to decode and decrypt payloads, which create a new class that cyber threat actors can execute to run arbitrary code.
Set 2 works together in the following ways:
  1. Loader 2 contains and loads WebAndroidAppInstaller.class at runtime.
    1. WebAndroidAppInstaller.class intercepts and processes specific HTTP requests, retrieves and decrypts password parameters from the request, defines and loads a new malicious class, encrypts and encodes the new class output, and generates a response with the encrypted output.
Malware Delivery
Note: This advisory uses the MITRE ATT&CK® for Enterprise framework, version 17. See Appendix A: MITRE ATT&CK Techniques for a table of the threat actors’ activity mapped to MITRE ATT&CK tactics and techniques.
The cyber threat actors delivered this malware in segments, splitting Loader 1 and 2 into multiple Base64-encoded segments [T1027.004]. They delivered each segment via separate HTTP GET requests and then used Java Expression Language (EL) injection to write each chunk and append them together using the append mode (via the true parameter).
For each loader, the actors’ first GET request created the file and wrote chunk 1. Their subsequent requests appended chunks to the existing file. Below is an example of the actors’ GET request.
"GET /mifs/rs/api/v2/featureusage?format=${"".getClass().forName("java.io.FileOutputStream").getConstructor("".getClass(), "".getClass().forName("[Z").getComponentType()).newInstance("/tmp/web-install.jar", true).write("".getClass().forName("java.util.Base64").getMethod("getDecoder").invoke(null).decode("[BASE64_CHUNK]"))
This argument creates/appends malware segments to the following file:
It then writes the following decoded Base64 chunk:
.write("".getClass().forName("java.util.Base64").getMethod("getDecoder").invoke(null).decode("[BASE64_CHUNK]")).
This technique is used for defense evasion—it enables the malware to evade signature-based detection and size limitations as it is transferred to the system. Holistically, this technique combines chunked encoding for evasion and file append operations for reconstruction.
Malware Metadata
Set 1
See Table 1 through Table 3 for metadata of the analyzed malware.
Table 1. Loader 1
Filename web-install.jar
Size 30996 bytes
Type JAR
MD5 e33103767524879293d1b576a8b6257d
SHA1 c2046523f1cb487a473b0a46a5a4a957f1b3200a
SHA256 c1f60ca5a5f7b94ab7122718a44b46de16c69d22c2eb62ce2948cab14bc78d50
SHA512 004b71ebeb4808b6dfdc4e58b95c4b307985c08118c45c02a34cd56ff697259199698989af0725d63802dfc785a72e416d2db5875edd1a0fa80ae01a282b2007
ssdeep 384:kaD+TLeDOl+mDcDFNUaD+TLeDOl+mDcDFNUaD+TLeDOl+mDcDFNUaD+TLeDOl+ms:z6Pl+mwj6Pl+mwj6Pl+mwj6Pl+mw3
Entropy 7.951890
Table 2. ReflectUtil.class Injector Malware
Filename ReflectUtil.class
Size 11886 bytes
Type compiled Java class data, version 49.0 (Java 1.5)
MD5 6ec2169312feb9fde0b17e244b32c37d
SHA1 6d7e85862f925e83f6d0c29e291765548fac721a
SHA256 065c1c2fb17ba1c3f882bead409215df612673cd455698768ed71412f9190ba3
SHA512 4cd26b298b448db6b26d91b8cf7ac169d693a0dad4f184742463db872b809b91d462ab4659bb21474578e3202bfc92b0db18716db6b4c3c24b3f9e7f2fccce27
ssdeep 192:KuZ4E9i44LYcyHCi3uFl0xEHqQ+k5bUW0sbh3aUfPuS6GZz:Ku79BP/3uFygq49V0stKEuSpz
Entropy 6.258794
Table 3. SecurityHandlerWanListener.class Malicious Listener
Filename SecurityHandlerWanListener.class
Size 4690 bytes
MD5  5e9d283b483b8d5c637baf7cfdda0e08
SHA1  8b87a881f6f81afb596d3f98abef4225315e26bf
SHA256 b1b1cf33b8d3da35293d6b74c378f0cd9452a4351e26d07c896c4d9a8257ef89
SHA512 07956b3a830bd0885202d9bc7a5b5a5927acf1c5584830ebc1011849f41b1077c3d6e3c2a6e94e36a338fc6b540c4b736751775e7069df4b257fa3786c1140a2
ssdeep 96:bFlm4Dt94EugELCBt+qRAVfOTqM8+U00RO:Blz94ExtlRAITqGQO
Entropy 5.690466
Set 2
See **Table 4 **through Table 5 for metadata of the analyzed malware.
Table 4. Loader 2
Size 8728 bytes
Type JAR
MD5  32f5c3c1582a77c004b1511c77454678
SHA1  2a96ce17ed8a025dd72f3729c247dfdb5b0a19a4
SHA256 b618057de9a8bba95440f23b9cf6374cc66f2acd127b3d478684b22d8f11e00b
SHA512 ec3880dfdc23a06cc1d97153963c3b0bd64db0469069e8dc3395101d12c65bcdcf87e5eac967ddf0b6be7e1dd6e8faaa233224f9f76a90f44f0e9df320d051a3
ssdeep 192:omBb/dSBuj9MLFgWfXsea1Xld+LXxzRlRX+pi+n9PshE6w0Tipbg8:j/T9MLFgWfcnVlSzspic9kCPxpB
Entropy 7.923820
Table 5. WebAndroidAppInstaller.class Malicious Listener
Filename WebAndroidAppInstaller.class
Size 16120 bytes
Type compiled Java class data, version 52.0 (Java 1.8)
MD5  8387a7ce9f2520d8956747fd247b19af
SHA1  9808ab3ddfb9ab4fe3af1b5d1f6a638bc03788e0
SHA256 df501b238854d6579cafebeba82581a728e89ed1f6cd0da54c79ef4eb6f4f9fd
SHA512 a51943a8381e67aca4b8296c9df0b05450525b5b27efbf873fd54a7f68febb503e1eb088d287e3561137fd33d3772dd879a3f00b09285a67f215f7a420e7ffcd
ssdeep 384:iI+1BxqQ3evK5c7aIUnKzaxckO05xiZMQn5JI3c+AK8:iImfqQ3z/nbax1
Entropy 5.950145
Malware Functionality
Set 1
This set of malware contains a loader, a manager, and a malicious listener.
Loader 1
Loader 1 is a Java Archive (JAR) file that contains [T1027.009] and loads the compiled Java class file ReflectUtil.class at runtime.
Loader 1 masquerades ReflectUtil.class as part of the org.apache.http package [T1036]. See Figure 1 for ReflectUtil.class’s hierarchal file path.
Figure 1 - Loader 1 Internal Structure
_Figure 1. Loader 1 Internal Structure _
ReflectUtil.class Manager
ReflectUtil.class manipulates Java objects to inject and manage the malicious listener SecurityHandlerWanListener in Apache Tomcat (which was running on the same compromised server). When executed, the file:
  1. Bypasses Java Development Kit (JDK) module restrictions.
  2. Iterates objects and their contexts.
  3. Attempts to load SecurityHandlerWanListener class in the JUnit environment or framework by using getClassName() to return the hard-coded string org.junit.SecurityHandlerWanListener [T1620].
If SecurityHandlerWanListener class is not loaded because it is not found when ReflectUtil.class first executes, ReflectUtil.class handles the error by using a Base64 string catch block (Figure 2) to Base64 decode, gzip decompress, and load the class SecurityHandlerWanListener.
Figure 2 - getBase64String() to Base64 Decode, gzip Decompress, and Load the Class
_Figure 2. getBase64String() to Base64 Decode, gzip Decompress, and Load the Class SecurityHandlerWanListener _
The Base64 string:
  1. Returns the Base64-encoded and gzip-compressed bytecode of class SecurityHandlerWanListener.
  2. Decodes and decompresses [T1140] the class bytecode (see Figure 3) in one of two ways:
    1. It first uses sun.misc.BASE64Decoder to call decodeBuffer.
    2. If the first attempt fails, it uses java.util.Base64 to call getDecoder.
Figure 3 - Java Code Snippet for Decoding a Base64 String
_Figure 3. Java Code Snippet for Decoding a Base64 String _
  1. Invokes the defineClass method of ClassLoader to load the class from the decompressed bytecode.
Once the class SecurityHandlerWanListener is loaded, ReflectUtil.class:
  1. Creates a new instance of the class and returns it as a new listener.
  2. Retrieves the current list of listeners, adds the new listener to this list, and updates the application's listener list.
  3. Checks if evilClassName has already been injected into the application's event listener list to avoid multiple injections or to confirm a previous injection. (CISA has no additional information on the listener evilClassName.)
This compiled Java class file is a malicious listener that intercepts specific HTTP requests and processes them to decode and decrypt payloads, which dynamically create and execute a new class.
The file uses ClassLoader to set up a custom servlet listener that intercepts HTTP requests [T1071.001] based on String Pass, Header Name, and Header Values. Specifically, when a new HTTP request is received, the servlet listener checks if the request contains the string pass 7c6a8867d728c3bb, Header Name Referer, and Header Value https://www[.]live.com.
If the fields match, the file creates a HashMap to store the request, response, and session objects. The file also stores the key 7c6a8867d728c3bb in the session.
The file then retrieves, decodes, and decrypts the Base64-encoded payload:
  1. The file retrieves the payload by reading a line from request’s input stream (request.getReader().readLine()).
  2. The file decodes the line using Base64.
  3. The file decrypts the decoded data using Advanced Encryption Standard (AES) cipher object with the stored key.
The file passes the decrypted data to a method named g, which defines and creates a new Java class file. Cyber threat actors can execute the class on the device to run arbitrary code.
Potential impact: This listener could allow cyber threat actors to:
  • Inject and execute arbitrary code on the server, enabling follow-on activity and persistence.
  • Exfiltrate data by intercepting and processing HTTP requests.
See Figure 4 for the relevant listener code snippet.
Figure 4 - Java Code Snippet
_Figure 4. Java Code Snippet _
Set 2
This set of malware contains a loader and a malicious listener.
Loader 2
This JAR file contains and loads the compiled Java class file WebAndroidAppInstaller.class at runtime.
The JAR file masquerades the class file as part of the com.mobileiron.service package. See Figure 5 for WebAndroidAppInstaller.class’s hierarchal file path.
Figure 5 - WebAndroidAppInstaller.class Hierarchical File Path
_Figure 5: WebAndroidAppInstaller.class Hierarchical File Path _
This compiled Java class file is a malicious listener that intercepts and processes specific HTTP requests, retrieves and decrypts password parameters from the request, defines and loads a new malicious class, encrypts and encodes the new class output, and generates a response with the encrypted output.
The listener first retrieves request and response objects from a Java ServletContext. Then, the file checks the request’s Content-Type to ensure it is not null and contains the string application/x-www-form-urlencoded.
If these conditions are met, the file retrieves a password parameter from the request. If the data is not null and has a length greater than zero, the password parameter value is Base64 decoded and decrypted using an AES algorithm with the hard-coded key 3c6e0b8a9c15224a [T1573.001].
If the decrypted data is not empty, the decrypted data defines and implements a new class. The file AES encrypts the new class output using the same hard-coded key, 3c6e0b8a9c15224a, and then Base64 encodes it [T1027.013].
The file then generates a Message Digest Algorithm 5 (MD5) hash of the data stored in the password parameter (from the initial HTTP request) and hard-coded key and checks if the hash value was stored in newly allocated byte array ByteArrayOutputStream. The file creates a PrintWriter object to generate a response containing the first 16 characters of the computed MD5 hash value, followed by the Base64-encoded and AES-encrypted output of the new loaded class and the remaining part of the MD5 hash value.
**Potential impact. **This listener could allow cyber threat actors to:
  • **Exfiltrate data **by receiving response and execution results.
See Figure 6 for the applicable Java code Snippet.
Figure 6 - WebAndroidAppInstaller.class Java Code
_Figure 6. WebAndroidAppInstaller.class Java Code _
Detection
Yara Rules
Deploy the CISA-created YARA rules in Table 6 to detect malicious activity.
Table 6. YARA Rules
Loader 1
rule CISA_251126_01 : trojan hides_artifacts { meta: author = “CISA Code & Media Analysis” incident = “251126” date = “2025-07-23” last_modified = “20250724_1615” actor = “n/a” family = “n/a” capabilities = “hides-artifacts” malware_type = “trojan” tool_type = “unknown” description = “Detects malicious jar filter samples” sha256_1 = “c1f60ca5a5f7b94ab7122718a44b46de16c69d22c2eb62ce2948cab14bc78d50” strings: $s0 = { 6F 72 67 2F 61 70 61 63 68 65 2F 68 74 74 70 2F 63 6C 69 65 6E 74 } $s1 = { 2F 77 6F 2F 52 65 66 6C 65 63 74 55 74 69 6C 2E 63 6C 61 73 73 } $s2 = { 83 2E 9D 42 02 A3 81 42 02 B3 C7 57 34 C4 A8 21 } $s3 = { 8C 8E C0 B6 14 0E 92 08 89 EE EB 1A 11 7D F4 4E } $s4 = { 5B 97 FF F6 12 C9 16 F5 17 C8 5B 5F 44 0E 07 30 } $s5 = { A9 21 59 ED 8E 7A 28 D6 29 FA E3 D0 4C 3D 0F CE } $s6 = { 5A BD F7 24 E8 66 5F 07 2F 7C 0C 0E A9 E3 8D C5 } $s7 = { 05 1B AE 97 B1 88 FF 01 16 EF 3F 44 9E 5F 43 AE } condition: all of them }
ReflectUtil.class
rule CISA_251126_02 : trojan { meta: author = “CISA Code & Media Analysis” incident = “251126” date = “2025-07-23” last_modified = “20250724_1615” actor = “n/a” family = “n/a” capabilities = “n/a” malware_type = “trojan” tool_type = “unknown” description = “Detects malicious servlet filter class loader samples” sha256_1 = “065c1c2fb17ba1c3f882bead409215df612673cd455698768ed71412f9190ba3” strings: $s0 = { 6F 72 67 2F 61 70 61 63 68 65 2F 68 74 74 70 } $s1 = { 63 6C 69 65 6E 74 2F 77 6F 2F 52 65 66 6C 65 63 74 55 74 69 6C } $s2 = { 53 65 63 75 72 69 74 79 48 61 6E 64 6C 65 72 57 61 6E 4C 69 73 74 65 6E 65 72 } $s3 = { 67 65 74 4C 69 73 74 65 6E 65 72 } $s4 = { 61 64 64 4C 69 73 74 65 6E 65 72 } $s5 = { 54 6F 6D 63 61 74 45 6D 62 65 64 64 65 64 43 6F 6E 74 65 78 74 } $s6 = { 67 7A 69 70 44 65 63 6F 6D 70 72 65 73 73 } $s7 = { 67 65 74 41 70 70 6C 69 63 61 74 69 6F 6E 45 76 65 6E 74 4C 69 73 74 65 6E 65 72 73 } $s8 = { 73 65 74 41 70 70 6C 69 63 61 74 69 6F 6E 45 76 65 6E 74 4C 69 73 74 65 6E 65 72 73 } $s9 = { 65 76 69 6C 43 6C 61 73 73 4E 61 6D 65 } condition: all of them }
rule CISA_251126_03 : trojan installs_other_components exfiltrates_data { meta: author = “CISA Code & Media Analysis” incident = “251126” date = “2025-07-23” last_modified = “20250724_1615” actor = “n/a” family = “n/a” capabilities = “installs-other-components exfiltrates-data” malware_type = “trojan” tool_type = “unknown” description = “Detects malicious servlet filter class samples” sha256_1 = “b1b1cf33b8d3da35293d6b74c378f0cd9452a4351e26d07c896c4d9a8257ef89” strings: $s0 = { 53 65 72 76 6C 65 74 52 65 71 75 65 73 74 4C 69 73 74 65 6E 65 72 } $s1 = { 43 6C 61 73 73 4C 6F 61 64 65 72 } $s2 = { 53 65 72 76 6C 65 74 52 65 71 75 65 73 74 45 76 65 6E 74 } $s3 = { 2F 48 74 74 70 53 65 72 76 6C 65 74 52 65 73 70 6F 6E 73 65 } $s4 = { 48 74 74 70 53 65 73 73 69 6F 6E } $s5 = { 48 74 74 70 53 65 72 76 6C 65 74 52 65 73 70 6F 6E 73 65 } $s6 = { 68 65 61 64 65 72 56 61 6C 75 65 } $s7 = { 37 63 36 61 38 38 36 37 64 37 32 38 63 33 62 62 } $s8 = { 70 61 73 73 } $s9 = { 53 65 63 72 65 74 4B 65 79 53 70 65 63 } $s10 = { 15 68 74 74 70 73 3A 2F 2F 77 77 77 2E 6C 69 76 65 2E 63 6F 6D 2F } $s11 = { 52 65 66 65 72 65 72 } condition: all of them }
Loader 2
rule CISA_251126_04 : trojan hides_artifacts { meta: author = “CISA Code & Media Analysis” incident = “251126” date = “2025-07-23” last_modified = “20250724_1615” actor = “n/a” family = “n/a” capabilities = “hides-artifacts” malware_type = “trojan” tool_type = “unknown” description = “Detects malicious jar Tomcat listener shell samples” sha256_1 = “b618057de9a8bba95440f23b9cf6374cc66f2acd127b3d478684b22d8f11e00b” strings: $s0 = { 63 6F 6D 2F 6D 6F 62 69 6C 65 69 72 6F 6E 2F 73 65 72 76 69 63 65 2F } $s1 = { 57 65 62 41 6E 64 72 6F 69 64 41 70 70 49 6E 73 74 61 6C 6C 65 72 2E 63 6C 61 73 73 } $s2 = { 5A 5D BB 33 C0 43 31 B0 2D DC 58 F2 75 44 CE E5 } $s3 = { 97 DC AC 0F A7 69 97 A4 5A 72 E8 96 AC 43 9E 01 } $s4 = { E0 E0 7E 40 F3 F8 87 30 C5 83 30 C5 43 14 E7 67 } $s5 = { DB E6 F7 F9 BD FC BE 75 00 BF 6F B3 59 B7 28 07 } $s6 = { C6 BF A4 1D 28 AB 7A B9 3E 09 B1 D8 E2 FA 09 36 } $s7 = { B8 0E 8E 0B 97 2D AE CF B4 B8 6E CD E5 E6 BA 92 } condition: all of them }
rule CISA_251126_05 : trojan installs_other_components exfiltrates_data { meta: author = “CISA Code & Media Analysis” incident = “251126_” date = “2025-07-23” last_modified = “20250724_1615” actor = “n/a” family = “n/a” capabilities = “installs-other-components exfiltrates-data” malware_type = “trojan” tool_type = “unknown” description = “Detects malicious Tomcat listener shell class samples” sha256_1 = “df501b238854d6579cafebeba82581a728e89ed1f6cd0da54c79ef4eb6f4f9fd” strings: $s0 = { 43 6C 61 73 73 4C 6F 61 64 65 72 } $s1 = { 6D 6F 62 69 6C 65 69 72 6F 6E 2F 73 65 72 76 69 63 65 } $s2 = { 57 65 62 41 6E 64 72 6F 69 64 41 70 70 49 6E 73 74 61 6C 6C 65 72 } $s3 = { 61 64 64 4C 69 73 74 65 6E 65 72 } $s4 = { 73 65 72 76 6C 65 74 52 65 71 75 65 73 74 4C 69 73 74 65 6E 65 72 43 6C 61 73 73 } $s5 = { 61 64 64 41 70 70 6C 69 63 61 74 69 6F 6E 45 76 65 6E 74 4C 69 73 74 65 6E 65 72 4D 65 74 68 6F 64 } $s6 = { 62 61 73 65 36 34 44 65 63 6F 64 65 } $s7 = { 63 6F 6E 74 65 6E 74 54 79 70 65 } $s8 = { 08 72 65 73 70 6F 6E 73 65 } $s9 = { 33 63 36 65 30 62 38 61 39 63 31 35 32 32 34 61 } $s10 = { 6B 70 61 73 73 6C 6F 67 69 6E } $s11 = { 53 65 72 76 6C 65 74 52 65 71 75 65 73 74 4C 69 73 74 65 6E 65 72 } $s12 = { 53 65 63 72 65 74 4B 65 79 53 70 65 63 } condition: all of them }
SIGMA Rule
Deploy the CISA-created SIGMA rule in Table 7 to detect malicious activity.
Table 7. SIGMA Rule
Loader Malware for Ivanti Mobile Management Systems
## CISA Code & Media Analysis ## ############ README ############### ## Edit rules and queries as needed for your hunt and based on your environment. ## Ensure your EDR/SIEM instance has enough memory to run these AND/OR condition-based queries. May take longer to run than conventional Sigma rule query. ## Do not edit “logsource-product:” unless you are editing this rule to meet specific logsources/fields and know your environment. ## TLP CLEAR may convert rules using online converter of choice. ################################### title: Detects Artifacts Based on MAR-251126, Ivanti EPMM CVE-2025-4427 and CVE-2025-4428 incident: 251126 tlp: CLEAR id: 83df757f-54e7-44a0-be21-ae2306ca3240 status: test description: Detects abused URL paths and suspicious commands used by Threat Actors on Ivanti Endpoint Manger Mobile (EPMM). Based on MAR-251126 as well as Unauthenticated Remote Code Execution Vulnerabilities CVE-2025-4427 and CVE-2025-4428. references:     - ‘MAR-251126’     - ‘https://projectdiscovery.io/blog/ivanti-remote-code-execution’     - ‘https://labs.watchtowr.com/expression-payloads-meet-mayhem-cve-2025-4427-and-cve-2025-4428/’     - ‘https://www.wiz.io/blog/ivanti-epmm-rce-vulnerability-chain-cve-2025-4427-cve-2025-4428’     - ‘https://threatprotect.qualys.com/2025/05/20/cisa-warns-of-ivanti-epmm-unauthenticated-remote-code-execution-vulnerabilities-cve-2025-4427-cve-2025-4428/’     - ‘https://profero.io/blog/ivanti-epmm-attacks’     - ‘https://github.com/rapid7/metasploit-framework/blob/26156dfac2e01379eb858a87aa85e2ecfea929ff/modules%2Fexploits%2Fmulti%2Fhttp%2Fivanti_epmm_rce_cve_2025_4427_4428.rb’    author: CISA Code & Media Analysis date: 2025-08-08 modified: 2025-08-13 tags:     - cve.2025.4427     - cve.2025.4428 logsource:     product: cma detection:     keywords:         - ‘GET’     keywords_1:         - ‘/api/v2/*’     keywords_2:         - ‘sh -i’         - ‘invoke’         - ‘java’         - ‘/dev/tcp/’         - ‘getRuntime’         - ‘.jar’         - ‘.class’         - ‘evilClassName’         - ‘ping’         - ‘dig’         - ‘curl’         - ‘wget’         - ‘fetch’         - ‘echo’       keywords_3:         - ‘chmod’     keywords_4:         - ‘+x’         - ‘a+r’         - ‘755’         - ‘/tmp’       keywords_5:         - ‘/mi/tomcat/webapps/mifs/401.jsp’         - ‘/mi/tomcat/webapps/mifs/css/css.css’         - ‘/mi/tomcat/webapps/mifs/session.jsp’          - ‘/mi/tomcat/webapps/mifs/baseURL.jsp’          - ‘065c1c2fb17ba1c3f882bead409215df612673cd455698768ed71412f9190ba3’          - ‘b618057de9a8bba95440f23b9cf6374cc66f2acd127b3d478684b22d8f11e00b’          - ‘c1f60ca5a5f7b94ab7122718a44b46de16c69d22c2eb62ce2948cab14bc78d50’          - ‘df501b238854d6579cafebeba82581a728e89ed1f6cd0da54c79ef4eb6f4f9fd’          - ‘1b1dda5e8e26da568559e0577769697c624df30e’          - ‘ac389c8b7f3d2fcf4fd73891f881b12b8343665b’          - ‘19b4df629f5b15e5ff742c70d2c7dc4dac29a7ce’          - ‘f780151c151b6cec853a278b4e847ef2af3dbc5d’          - ‘dce8faf5fcf5998b6802995914caa988ee1ebd92’          - ‘aa2cfeeca6c8e7743ad1a5996fe5ccc3d52e901d’          - ‘2bd61ce5bdd258c7dcbef53aedb1b018b8e0ae26’          - ‘82.132.235.212’          - ‘37.219.84.22’          - ‘88.194.29.21’          - ‘27.25.148.183’          - ‘83.229.126.234’          - ‘91.193.19.109’          - ‘47.120.74.19’          - ‘100.26.51.59’          - ‘150.241.71.231’          - ‘75.170.92.132’          - ‘5.181.159.149’          - ‘45.38.17.43’          - ‘75.170.92.132’       condition: keywords and keywords_1 and keywords_2 or keywords and keywords_1 and keywords_3 or keywords_3 and keywords_4 or keywords_5   falsepositives:     - Rate of FP low-moderate with some strings.     - Use this rule in an infected environment/logs.     - Analyst may need to make adjustments to the query as required. level: high
Incident Response
If this or similar malware is detected, CISA recommends that organizations:
  1. Quarantine or take offline potentially affected hosts.
  2. Collect and review artifacts, such as running processes/services, unusual authentications, and recent network connections.
  3. Capture a full forensic disk image of the affected host for sharing with CISA.
  4. If initial investigation (Step 2) finds the threat actor’s access was limited (e.g., they did not move laterally or elevate privileges), provision new account credentials. If the investigation finds the threat actor had broader access or potentially moved laterally, follow your organization’s incident response plans to initiate threat hunting, containment, and eviction measures.
  5. Report the compromise to CISA:
    1. Report the compromise via CISA’s 24/7 Operations Center ([email protected] or 1-844-729-2472) or CISA’s Incident Reporting System.
    2. Use CISA’s Malware Analysis Submission Form to submit a file containing the malicious code. Include the CISA-provided Incident ID number (obtained from reporting the compromise) in the Open Incident ID field.
  6. Reimage compromised hosts.
  7. Apply recommendations from the Mitigations section to harden the systems.
Mitigations
CISA recommends organizations implement the mitigations below to improve your organization’s cybersecurity posture on the basis of the threat actors’ activity. These mitigations align with the Cross-Sector Cybersecurity Performance Goals (CPGs) developed by CISA and the National Institute of Standards and Technology (NIST). The CPGs provide a minimum set of practices and protections that CISA and NIST recommend all organizations implement. CISA and NIST based the CPGs on existing cybersecurity frameworks and guidance to protect against the most common and impactful threats, tactics, techniques, and procedures. Visit CISA’s CPGs webpage for more information on the CPGs, including additional recommended baseline protections.
  • Upgrade Ivanti EPMM versions to the latest version as soon as possible.
  • Treat mobile device management (MDM) systems as high-value assets (HVAs) with additional restrictions and monitoring. MDM systems provide elevated access to thousands of hosts and should be treated as HVAs with additional restrictions and monitoring.
  • Follow best cybersecurity practices in production and enterprise environments, including mandating phishing-resistant multifactor authentication (MFA) for all staff and services. For additional best practices, see CISA’s Cross-Sector Cybersecurity Performance Goals (CPGs).
Disclaimer
CISA does not endorse any commercial entity, product, company, or service, including any entities, products, companies, or services linked within this document. Any reference to specific commercial entities, products, processes, or services by service mark, trademark, manufacturer, or otherwise, does not constitute or imply endorsement, recommendation, or favoring by CISA.
Version History
September 18, 2025: Initial version.
See Table 8 and Table 9 for all referenced threat actor tactics and techniques in this advisory. For assistance with mapping malicious cyber activity to the MITRE ATT&CK framework, see CISA and MITRE ATT&CK’s Best Practices for MITRE ATT&CK Mapping and CISA’s Decider Tool.
Table 8. Defense Evasion
Technique Title  ID Use
Obfuscated Files or Information: Compile After Delivery T1027.004 The cyber threat actors delivered malware in segments, splitting it into multiple Base64-encoded segments. The actors used Java EL injection to write each chunk and append them together using the append mode (via the true parameter).
Obfuscated Files or Information: Embedded Payloads T1027.009 Loader 1 contains ReflectUtil.class.
Obfuscated Files or Information: Encrypted/Encoded File T1027.013 WebAndroidAppInstaller.class AES encrypts and Base64 encodes a class output with a hard coded key.
Masquerading T1036 Loader 1 masquerades ReflectUtil.class as part of the org.apache.http package. Loader 2 masquerades WebAndroidAppInstaller.class as part of the com.mobileiron.service package.
Reflective Code Loading T1620 ReflectUtil.class reflectively loads code into Java processes to add a malicious listener to Apache Tomcat servers.
Deobfuscate/Decode Files or Information T1140 ReflectUtil.class decodes and decompresses a class bytecode.
Application Layer Protocol: Web Protocols T1071.001 SecurityHandlerWanListener.class intercepts HTTP requests. WebAndroidAppInstaller.class intercepts and processes specific HTTP requests.
Encrypted Channel: Symmetric Cryptography T1573.001 WebAndroidAppInstaller.class decodes a Base64 password parameter value using an AES algorithm and hard-coded key.
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/analysis-reports/ar25-261a
