Siemens Apogee PXC and Talon TC Devices
  • CVSS v4 6.3
  • Equipment: Apogee PXC and Talon TC Devices
  • Vulnerability: Exposure of Sensitive Information to an Unauthorized Actor
Successful exploitation of this vulnerability could allow an attacker to download the device's encrypted database file via BACnet.
  • APOGEE PXC Series (BACnet): All versions
  • APOGEE PXC Series (P2 Ethernet): All versions
  • TALON TC Series (BACnet): All versions
3.2.1 EXPOSURE OF SENSITIVE INFORMATION TO AN UNAUTHORIZED ACTOR CWE-200
Affected devices connected to the network allow unrestricted access to sensitive files, such as databases. This could allow an attacker to download encrypted .db file containing passwords.
CVE-2025-40757 has been assigned to this vulnerability. A CVSS v3.1 base score of 5.3 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:L/I:N/A:N).
A CVSS v4 score has also been calculated for CVE-2025-40757. A base score of 6.3 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:P/PR:N/UI:N/VC:L/VI:N/VA:N/SC:N/SI:N/SA:N).
Johnathan Law of PwC reported this vulnerability to Siemens. Siemens reported this vulnerability to CISA.
  • Ensure all three default passwords are changed, even if not in use.
  • Ensure that passwords for all accounts are strong and hard to guess. Passwords can be 15 characters long and can contain upper case, lower case, numbers and special characters.
  • Disable telnet (telnet is disabled by default).
For more information see the associated Siemens security advisory SSA-916339 in HTML and CSAF.
  • September 11, 2025: Initial Republication of Siemens ProductCERT SSA-916339
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-254-05
