Rockwell Automation 1783-NATR
  • CVSS v4 6.9
  • Equipment: 1783-NATR
  • Vulnerability: Use of Platform-Dependent Third Party Components
Successful exploitation of this vulnerability could allow an attacker to cause a memory corruption on the product.
The following versions of Rockwell Automation 1783-NATR are affected:
  • 1783-NATR: All versions prior to 1.007
3.2.1 USE OF PLATFORM-DEPENDENT THIRD PARTY COMPONENTS CWE-1103
In Wind River VxWorks, memory allocator has a possible overflow in calculating the memory block's size to be allocated by calloc(). As a result, the actual memory allocated is smaller than the buffer size specified by the arguments, leading to memory corruption.
CVE-2020-28895 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.3 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:L/I:L/A:L).
A CVSS v4 score has also been calculated for CVE-2020-28895. A base score of 6.9 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:L/VI:L/VA:L/SC:N/SI:N/SA:N).
Rockwell Automation released a product update addressing this vulnerability:
  • Version 1.007
Users of the affected software unable to upgrade to one of the corrected versions should follow Rockwell Automation's security best practices.
  • September 9, 2025: Initial Republication of Rockwell Automation advisory
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-252-09
