Aller au contenu principal
IT BIBLESe connecter
Honeywell OneWireless Wireless Device Manager (WDM)
  • CVSS v4 8.8
  • Vendor: Honeywell
  • Equipment: OneWireless Wireless Device Manager (WDM)
  • Vulnerabilities: Improper Restriction of Operations within the Bounds of a Memory Buffer, Sensitive Information in Resource Not Removed Before Reuse, Integer Underflow (Wrap or Wraparound), Deployment of Wrong Handler
Successful exploitation of these vulnerabilities could result in information exposure, denial of service, or remote code execution.
Honeywell reports these vulnerabilities affect the following:
  • OneWireless WDM: All releases prior to R322.5
  • OneWireless WDM: All releases prior to R331.1
3.2.1 IMPROPER RESTRICTION OF OPERATIONS WITHIN THE BOUNDS OF A MEMORY BUFFER CWE-119
The Honeywell OneWireless WDM contains a memory buffer vulnerability in the component Control Data Access (CDA). An attacker could potentially exploit this vulnerability, leading to buffer overread, which could result in improper index validation against buffer borders leading to remote code execution.
CVE-2025-2521 has been assigned to this vulnerability. A CVSS v3.1 base score of 8.6 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:L/I:L/A:H).
A CVSS v4 score has also been calculated for CVE-2025-2521. A base score of 8.5 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:N/UI:N/VC:L/VI:L/VA:H/SC:N/SI:N/SA:N).
3.2.2 SENSITIVE INFORMATION IN RESOURCE NOT REMOVED BEFORE REUSE CWE-226
The Honeywell OneWireless WDM contains a sensitive information in resource vulnerability in the component Control Data Access (CDA). An attacker could potentially exploit this vulnerability, leading to a communication channel manipulation, which could result in buffer reuse which may cause incorrect system behavior.
CVE-2025-2522 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.5 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:L/I:L/A:N).
A CVSS v4 score has also been calculated for CVE-2025-2522. A base score of 6.9 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:N/UI:N/VC:L/VI:L/VA:N/SC:N/SI:N/SA:N).
3.2.3 INTEGER UNDERFLOW (WRAP OR WRAPAROUND) CWE-191
The Honeywell OneWireless WDM contains an integer underflow vulnerability in the component Control Data Access (CDA). An attacker could potentially exploit this vulnerability, leading to a communication channel manipulation, which could result in a failure during subtraction, allowing remote code execution.
CVE-2025-2523 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.4 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:L/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-2523. A base score of 8.8 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:N/UI:N/VC:L/VI:H/VA:H/SC:N/SI:N/SA:N).
3.2.4 DEPLOYMENT OF WRONG HANDLER CWE-430
The Honeywell OneWireless WDM contains a deployment of wrong handler vulnerability in the component Control Data Access (CDA). An attacker could potentially exploit this vulnerability, leading to input data manipulation, which could result in incorrect handling of packets, leading to remote code execution.
CVE-2025-3946 has been assigned to this vulnerability. A CVSS v3.1 base score of 8.2 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:L/A:H).
A CVSS v4 score has also been calculated for CVE-2025-3946. A base score of 8.8 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:N/UI:N/VC:N/VI:L/VA:H/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Chemical, Energy
Demid Uzenkov and Kirill Kutaev of Positive Technologies reported these vulnerabilities to Honeywell.
Honeywell recommends updating OneWireless WDM to R322.5 or R331.1. For more information, see the security notice.
  • When remote access is required, use more secure methods, such as virtual private networks (VPNs), recognizing VPNs may have vulnerabilities and should be updated to the most current version available. Also recognize VPN is only as secure as the connected devices.
  • September 4, 2025: Initial Republication of Honeywell security notification
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-247-01
Se connecter pour répondre.
