Delta Electronics EIP Builder
  • CVSS v4 6.7
  • Vendor: Delta Electronics
  • Equipment: EIP Builder
  • Vulnerability: Improper Restriction of XML External Entity Reference
Successful exploitation of this vulnerability could allow an attacker to potentially process dangerous external entities, resulting in disclosure of sensitive information.
The following Delta Electronics products are affected:
  • EIP Builder: Versions 1.11 and prior
3.2.1 IMPROPER RESTRICTION OF XML EXTERNAL ENTITY REFERENCE CWE-611
The affected product is vulnerable to an XML external entity vulnerability, which could allow an attacker to disclose sensitive information.
CVE-2025-57704 has been assigned to this vulnerability. A CVSS v3.1 base score of 5.5 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:N/UI:R/S:U/C:H/I:N/A:N).
A CVSS v4 score has also been calculated for CVE-2025-57704. A base score of 6.7 has been calculated; the CVSS vector string is (AV:L/AC:L/AT:N/PR:N/UI:A/VC:H/VI:N/VA:N/SC:N/SI:N/SA:N).
kimiya working with Trend Micro Zero Day Initiative reported this vulnerability to CISA.
Delta Electronics recommends users updating to V1.12.
For more information refer to Delta Electronics' security advisory Delta-PCSA-2025-00013.
Delta Electronics offers the following general recommendations:
  • Do not click on untrusted Internet links or open unsolicited email attachments.
  • Place systems and devices behind a firewall and isolate them from the business network.
If you have any product-related support concerns, find a contact from the Delta Electronics portal page for any information or materials you may require.
  • September 2, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-245-01
