Delta Electronics COMMGR
  • CVSS v4 8.8
  • Vendor: Delta Electronics
  • Equipment: COMMGR
  • Vulnerabilities: Stack-based Buffer Overflow, Code Injection
Successful exploitation of these vulnerabilities could allow an attacker to execute arbitrary code.
The following versions of Delta Electronics COMMGR are affected:
  • COMMGR: Versions v2.9.0 and prior
Delta Electronics COMMGR versions 2.9.0 and prior are vulnerable to a Stack-based Buffer Overflow vulnerability that could allow an attacker to execute arbitrary code by crafting specially designed .isp files.
CVE-2025-53418 has been assigned to this vulnerability. A CVSS v3.1 base score of 8.6 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:L/I:L/A:H).
A CVSS v4 score has also been calculated for CVE-2025-53418. A base score of 8.8 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:L/VI:L/VA:H/SC:N/SI:N/SA:N).
3.2.2 IMPROPER CONTROL OF GENERATION OF CODE ('CODE INJECTION') CWE-94
Delta Electronics COMMGR versions 2.9.0 and prior are vulnerable to a Code Injection vulnerability that could allow an attacker to execute arbitrary code by crafting specially designed .isp files.
CVE-2025-53419 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.8 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-53419. A base score of 8.4 has been calculated; the CVSS vector string is (AV:L/AC:L/AT:N/PR:N/UI:A/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
Delta Electronics reported CVE-2025-53418 to CISA. Guillaume Orlando working with Trend Micro Zero Day Initiative reported CVE-2025-53419 to CISA.
Delta Electronics recommends users to download and update to v2.10.0 or later.
Delta Electronics offers users the following general recommendations:
  • Do not click on untrusted Internet links or open unsolicited attachments in emails.
  • Place control system networks and remote devices behind firewalls and isolate them from the business network.
For more information, see Delta Electroncis's Advisory.
  • August 28, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-240-05
