Delta Electronics CNCSoft-G2
  • CVSS v4 8.5
  • Vendor: Delta Electronics
  • Equipment: CNCSoft-G2
  • Vulnerability: Out-of-bounds Write
Successful exploitation of this vulnerability could allow attackers to execute arbitrary code on affected installations of the device.
The following versions of Delta Electronics CNCSoft-G2 are affected:
  • CNCSoft-G2: Version 2.1.0.20 and prior
Delta Electronics CNCSoft-G2 is vulnerable to a flaw in the parsing of DPAX files that allows attackers to execute arbitrary code. This vulnerability requires user interaction, such as visiting a malicious page or opening a malicious file. Exploitation of this flaw can result in memory corruption and code execution within the context of the current process.
CVE-2025-47728 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.8 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-47728. A base score of 8.5 has been calculated; the CVSS vector string is (AV:L/AC:L/AT:N/PR:N/UI:P/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
Natnael Samson (@NattiSamson) working with Trend Micro Zero Day Initiative reported this vulnerability to CISA.
Delta Electronics recommends users update to v2.1.0.27 or later.
Delta has published Delta-PCSA-2025-00007 in both English and Chinese on their security website to provide more details about these issues.
Delta also recommends the following general security practices:
  • Do not click on untrusted Internet links or open unsolicited attachments in emails.
  • Place systems and devices behind a firewall and isolate them from the business network.
If you have any product-related support concerns, find a contact from Delta's portal page for any information or materials you may require.
  • August 28, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-240-04
