Rockwell Automation FLEX 5000 I/O
  • Equipment: FLEX 5000 I/O
  • Vulnerabilities: Improper Input Validation
Successful exploitation of these vulnerabilities could create a denial-of-service condition.
The following version of FLEX 5000 I/O is affected:
  • 5069-IF8: version V2.011 (CVE-2025-7861)
  • 5069-IY8: version V2.011 (CVE-2025-7862)
A security issue exists due to improper handling of CIP Class 32's request when a module is inhibited on the 5094-IF8 device. It causes the module to enter a fault state with the Module LED flashing red. Upon un-inhibiting, the module returns a connection fault (Code 16#0010), and the module cannot recover without a power cycle.
CVE-2025-7861 has been assigned to this vulnerability. A CVSS v3 base score of 7.5 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:H).
A CVSS v4 score has also been calculated for CVE-2025-7861. A base score of 8.7 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:N/VI:N/VA:H/SC:N/SI:N/SA:N).
3.2.2 IMPROPER INPUT VALIDATION CWE-20
A security issue exists due to improper handling of CIP Class 32's request when a module is inhibited on the 5094-IY8 device. It causes the module to enter a fault state with the Module LED flashing red. Upon un-inhibiting, the module returns a connection fault (Code 16#0010), and the module cannot recover without a power cycle.
CVE-2025-7862 has been assigned to this vulnerability. A CVSS v3 base score of 7.5 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:H/E:U/RL:O/RC:C).
A CVSS v4 score has also been calculated for CVE-2025-7862. A base score of 8.7 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:N/VI:N/VA:H/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Chemical, Critical Manufacturing, Energy, Food and Agriculture, Transportation Systems, Water and Wastewater
Rockwell Automation recommends users upgrade to V2.012 or later. The update can be downloaded from Rockwell Automation's website.
Rockwell Automation also recommends users follow their published Security Best Practices.
  • August 14, 2025: Initial Republication: Initial Republication of Rockwell Automation’s SD1737
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-226-26
