Aller au contenu principal
IT BIBLESe connecter
Rockwell Automation FactoryTalk Viewpoint
  • CVSS v4 8.5
  • Equipment: FactoryTalk Viewpoint
  • Vulnerability: Improper Handling of Insufficient Permissions or Privileges
Successful exploitation of this vulnerability could result in full privilege escalation.
The following version of FactoryTalk Viewpoint is affected:
  • FactoryTalk Viewpoint: Version 14.00 and prior
3.2.1 EXECUTION WITH UNNECESSARY PRIVILEGES CWE-250
A security issue exists in FactoryTalk ViewPoint version 14.0 or below due to improper handling of MSI repair operations. During a repair, attackers can hijack the cscript.exe console window, which runs with SYSTEM privileges. This can be exploited to spawn an elevated command prompt, enabling full privilege escalation.
CVE-2025-7973 has been assigned to this vulnerability. A CVSS v3 base score of 7.8 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:L/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-7973. A base score of 8.5 has been calculated; the CVSS vector string is (AV:L/AC:L/AT:N/PR:L/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
Update the affected product to version 15.00 or later.
If those using the affected software are not able to upgrade the version, security best practices should be applied.
  • August 14, 2025: Initial Republication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-266-23
Se connecter pour répondre.
